Aller au contenu principal
Packard Bell EasyNote TJ65-CU-030GE Battery Replacement
  1. Packard Bell EasyNote TJ65-CU-030GE Battery Replacement, Battery: étape 1, image 1 de 2 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement, Battery: étape 1, image 2 de 2
    • The battery is located on the top left corner of the backside of the device.
    • On the left side underneath the battery drawer, you can see two battery lock switches located in the shape of a T.
    • At the beginning, both switches should be switched to the locked position.
  2. Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: étape 2, image 1 de 3 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: étape 2, image 2 de 3 Packard Bell EasyNote TJ65-CU-030GE Battery Replacement: étape 2, image 3 de 3
    • Slide the vertical battery lock switch downwards to the image of the unlocked padlock.
    • Now you can move the horizontal battery lock switch to the right.
    • You need to apply some pressure to fully move over the switch. At the hardest part, the battery drawer will spring open.
    • Now you can remove the battery block completely.
    • By doing this, the horizontal switchlock will jump back to its original position on the left side.
5 autres ont terminé cette réparation.
Jasmin
Membre depuis le 02/17/16
407 Réputation
1 tutoriel rédigé
Équipe
iFixit EU Team Membre de l'équipe iFixit EU Team
Community
53 membres
1 000 tutoriels rédigés
3 commentaires
I am trying to find out how I have managed to turn off the battery on my packardbell easy note ENTG71BM. Any ideas?
julie crockford - Réponse
I am tring to turn on the pc, but the only thing it does is making noise of the fan repeatedly without lighting the screen.
siyabonga - Réponse
Solution could be as simple as selecting the right video output mode, follow the first hint from the most useful answer in this thread https://it.ifixit.com/Risposte/Visualizz.... If it helped you solve your problem, please feel free to leave a feedback to the author of the post, otherwise I suggest you try asking directly in the above-mentioned dedicated topic
Simone -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 17
30 derniers jours : 87
Total : 6,838
