Aller au contenu principal
Packard Bell EasyNote TJ65-CU-030GE hdd Replacement
Ce dont vous avez besoin
  1. Packard Bell EasyNote TJ65-CU-030GE hdd Replacement, battery and keyboard: étape 1, image 1 de 3 Packard Bell EasyNote TJ65-CU-030GE hdd Replacement, battery and keyboard: étape 1, image 2 de 3 Packard Bell EasyNote TJ65-CU-030GE hdd Replacement, battery and keyboard: étape 1, image 3 de 3
    • first remove battery
    • secondly with a flat thin screwdriver clip keyboard
  2. Packard Bell EasyNote TJ65-CU-030GE hdd Replacement, disconnecting/unplugging the keyboard cable: étape 2, image 1 de 3 Packard Bell EasyNote TJ65-CU-030GE hdd Replacement, disconnecting/unplugging the keyboard cable: étape 2, image 2 de 3 Packard Bell EasyNote TJ65-CU-030GE hdd Replacement, disconnecting/unplugging the keyboard cable: étape 2, image 3 de 3
    • carefully flip keyboard
    • lift the black bracket that holds the keyboard
    • look for the screws that have DOOR written near them
  3. Packard Bell EasyNote TJ65-CU-030GE hdd Replacement, opening the back cover: étape 3, image 1 de 3 Packard Bell EasyNote TJ65-CU-030GE hdd Replacement, opening the back cover: étape 3, image 2 de 3 Packard Bell EasyNote TJ65-CU-030GE hdd Replacement, opening the back cover: étape 3, image 3 de 3
    • start unscrewing
    • there should be 4 of them
    • next press the plastic near the DOOR RELEASE text while making sure there`s nothing preventing the rear door from opening
  4. Packard Bell EasyNote TJ65-CU-030GE hdd Replacement, removing HDD cable and inserting the new one: étape 4, image 1 de 2 Packard Bell EasyNote TJ65-CU-030GE hdd Replacement, removing HDD cable and inserting the new one: étape 4, image 2 de 2
    • lift hdd with any screwdriver
    • remove the cable
    • add the new HDD/SSD
    • and now follow the steps backwards to reassemble
Harfas
Membre depuis le 08/25/21
109 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 14
30 derniers jours : 27
Total : 553
