Aller au contenu principal
Palm IIIx Touch Screen Replacement
Ce dont vous avez besoin
  1. Palm IIIx Touch Screen Replacement, Battery: étape 1, image 1 de 1
    • Place the Palm IIIx face down on a flat surface.
  2. Palm IIIx Touch Screen Replacement: étape 2, image 1 de 1
    • Push down and lift up the battery cover to remove it.
  3. Palm IIIx Touch Screen Replacement: étape 3, image 1 de 1
    • Remove the old batteries one at a time.
  4. Palm IIIx Touch Screen Replacement, Touch Screen: étape 4, image 1 de 1
    • Using a Phillips #00 screwdriver, remove the four screws that hold the back cover in place.
  5. Palm IIIx Touch Screen Replacement: étape 5, image 1 de 1
    • Hold the device on its side, positioning your hands as shown.
    • Remove the back cover by pushing in with your thumbs and pulling outward with the rest of your fingers.
  6. Palm IIIx Touch Screen Replacement: étape 6, image 1 de 1
    • Hold the screen and front cover on its side, facing the screen inward as shown.
    • Position your hands so that you can push the screen outward with your thumbs.
    • Remove the screen by pushing outward with your thumbs. Use your index fingers to hold the front cover in place.
  7. Palm IIIx Touch Screen Replacement: étape 7, image 1 de 2 Palm IIIx Touch Screen Replacement: étape 7, image 2 de 2
    • Position the device with the screen facing down.
    • Locate the white ribbon wire on the left hand side of the device.
    • On either side of the ribbon wire are two white clasps. Gently push the two clasps away from the board (to the left).
  8. Palm IIIx Touch Screen Replacement: étape 8, image 1 de 1
    • Detach the ribbon wire by gently pulling it out of its connector.
  9. Palm IIIx Touch Screen Replacement: étape 9, image 1 de 1
    • Separate the motherboard from the screen.
  10. Palm IIIx Touch Screen Replacement: étape 10, image 1 de 2 Palm IIIx Touch Screen Replacement: étape 10, image 2 de 2
    • On the back of the screen near the top right corner is a plastic filament:
    • Gently lift up on the two brown clasps on either side of the filament connector as shown.
    • Using a thin, blunt object (a toothpick works well), slide it under the plastic filament and lift up to detach the filament from its connector.
  11. Palm IIIx Touch Screen Replacement: étape 11, image 1 de 1
    • Insert a spudger tool between the metal backing and the glass cover piece, as shown.
    • Run the spudger along the edge of the screen until the screen is lifted and can be removed.
    • Replace or clean as needed.
David Haskell
Membre depuis le 01/21/10
44 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 14-43, Regan Winter 2010 Membre de l'équipe Cal Poly, Team 14-43, Regan Winter 2010
CPSU-REGAN-W10S14G43
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 2,401
