Aller au contenu principal
Palm Pre 2 Motherboard Replacement
Ce dont vous avez besoin
  1. Palm Pre 2 Motherboard Replacement, Motherboard: étape 1, image 1 de 2 Palm Pre 2 Motherboard Replacement, Motherboard: étape 1, image 2 de 2
    • Make sure your Palm Pre 2 is turned off before taking apart the phone.
    • Snap off the back panel to reveal the battery using the opening tool.
  2. Palm Pre 2 Motherboard Replacement: étape 2, image 1 de 3 Palm Pre 2 Motherboard Replacement: étape 2, image 2 de 3 Palm Pre 2 Motherboard Replacement: étape 2, image 3 de 3
    • Pull on the tab to remove the battery.
  3. Palm Pre 2 Motherboard Replacement: étape 3, image 1 de 2 Palm Pre 2 Motherboard Replacement: étape 3, image 2 de 2
    • Use the T5 Torx Screwdriver to remove the six screws that hold the back of the frame in place.
  4. Palm Pre 2 Motherboard Replacement: étape 4, image 1 de 2 Palm Pre 2 Motherboard Replacement: étape 4, image 2 de 2
    • Use a spudger to open the hinge that covers the black and white GPS and DIV antennas (Reference the red box in the image).
    • Use tweezers to remove the two antennas from the keypad control board.
  5. Palm Pre 2 Motherboard Replacement: étape 5, image 1 de 2 Palm Pre 2 Motherboard Replacement: étape 5, image 2 de 2
    • Use the opening tool to pry off the (black and yellow) back frame.
  6. Palm Pre 2 Motherboard Replacement: étape 6, image 1 de 3 Palm Pre 2 Motherboard Replacement: étape 6, image 2 de 3 Palm Pre 2 Motherboard Replacement: étape 6, image 3 de 3
    • Use the opening tool to remove the panel on the main part of the phone.
    • Use the tweezers to get access to remove the panel giving access to the cable connectors.
    • Remove the two ribbon cable connectors using the tweezers.
  7. Palm Pre 2 Motherboard Replacement: étape 7, image 1 de 1
    • Use tweezers to separate the keyboard from the phone.
  8. Palm Pre 2 Motherboard Replacement: étape 8, image 1 de 2 Palm Pre 2 Motherboard Replacement: étape 8, image 2 de 2
    • Use a Phillips #0 screwdriver to remove the remaining 4 screws from the main portion of the phone.
    • Use an opening tool to remove the motherboard.
Cole Simmerman
Membre depuis le 01/08/18
160 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G6, Freund Spring 2018 Membre de l'équipe IUPUI, Team S1-G6, Freund Spring 2018
IUPUI-FREUND-S18S1G6
2 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 257
