Aller au contenu principal
Palm Rest Disassembly
Ce dont vous avez besoin
  1. Palm Rest Disassembly, Battery: étape 1, image 1 de 1
    • Turn power off using the power button located in the top left corner of the keyboard. Press and hold the power button for 3 seconds until it turns off.
  2. Palm Rest Disassembly: étape 2, image 1 de 2 Palm Rest Disassembly: étape 2, image 2 de 2
    • Close the laptop and flip it over so that the HP cover logo is on the underside of the laptop.
  3. Palm Rest Disassembly: étape 3, image 1 de 2 Palm Rest Disassembly: étape 3, image 2 de 2
    • Locate the battery and the two switches that release the battery when they are unlocked.
  4. Palm Rest Disassembly: étape 4, image 1 de 2 Palm Rest Disassembly: étape 4, image 2 de 2
    • Slide the left switch to the right so that the icon of a locked padlock is no longer visible and the icon of an unlocked padlock is now visible.
  5. Palm Rest Disassembly: étape 5, image 1 de 3 Palm Rest Disassembly: étape 5, image 2 de 3 Palm Rest Disassembly: étape 5, image 3 de 3
    • With your left hand, slide the right switch to the left and hold it in place. This will unlock the battery and allow you to easily slide it out of its port.
    • While holding the switch in place, use your right hand to gently remove the battery from its port.
  6. Palm Rest Disassembly, Palm Rest Disassembly: étape 6, image 1 de 1
    • Remove the thirteen 7 mm PH1 Phillips head screws from the bottom of the laptop.
  7. Palm Rest Disassembly: étape 7, image 1 de 1
    • Pry up and detach the keyboard. Starting at the top, slowly work the side and pull the keyboard away from you to unseat the bottom tabs.
  8. Palm Rest Disassembly: étape 8, image 1 de 1
    • Remove the keyboard connection from the laptop by flipping up the black tab on the ZIF connector.
  9. Palm Rest Disassembly: étape 9, image 1 de 2 Palm Rest Disassembly: étape 9, image 2 de 2
    • Remove the palm rest using the blue spudger tool.
  10. Palm Rest Disassembly: étape 10, image 1 de 1
    • Remove the five 3 mm PH1 Phillips head screws underneath keyboard.
  11. Palm Rest Disassembly: étape 11, image 1 de 1
    • Remove metal keyboard underlayment.
    • There is no way to separate the palm rest from the keyboard. They both are removed as an assembly.
Benjamin Poirier
Membre depuis le 10/17/17
503 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G4, Simcock Fall 2017 Membre de l'équipe UMass Dartmouth, Team S1-G4, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 12
Total : 1,303
