Introduction
This guide will walk you through the steps to remove the display from a Palm T|X.
Ce dont vous avez besoin
Orient the device so that the display faces forward.
Remove the stylus from the right side.
Use a soldering iron to disconnect the battery wires from the motherboard.
For soldering instructions, you can view the Soldering Guide.
Pull straight up on the ribbon cables located on the bottom right of the motherboard to disconnect them.
Orient the device sideways, as shown in the picture.
Lightly push the front of the display to separate it from the front panel.
Oh yes… that battery “certainly” won’t be attached at this point... *wink* - I understand the logic of disconnecting the battery from the motherboard, but most electronics these days have batteries with connectors. For such a simple process, as long as you’re careful with the motherboard and the battery, leave it soldered on. You don’t want to risk damaging the motherboard with excessive heat, especially if you are intermediate in the art of soldering.
3 autres ont terminé cette réparation.
2 commentaires
It's not necessary to unsolder the battery back for this at all, as long as you're careful not to pull on the battery wires, all you have to do is leave it attached and make sure it doesn't move too far from the board.
This stops with the display supposedly still firmly attached to the motherboard. How is this a display replacement procedure?
