Aller au contenu principal
Palm Treo 650 Motherboard Replacement
Ce dont vous avez besoin
  1. Palm Treo 650 Motherboard Replacement, Battery and Stylus: étape 1, image 1 de 1
    • Position the phone so the screen faces down.
    • Remove the stylus found on the back of the phone.
  2. Palm Treo 650 Motherboard Replacement: étape 2, image 1 de 1
    • Hold the button in the middle of the phone's back to remove the battery cover.
    • Slide the cover down to remove it, and set the cover aside.
  3. Palm Treo 650 Motherboard Replacement: étape 3, image 1 de 2 Palm Treo 650 Motherboard Replacement: étape 3, image 2 de 2
    • Lift the edge of the battery, separating contact points, and pull out as pictured.
  4. Palm Treo 650 Motherboard Replacement, Case: étape 4, image 1 de 1
    • Remove the round, rubber cover to expose a screw that will be removed in the next step.
  5. Palm Treo 650 Motherboard Replacement: étape 5, image 1 de 2 Palm Treo 650 Motherboard Replacement: étape 5, image 2 de 2
    • Remove the six 6.9 mm screws as pictured with a T5 Torx screwdriver.
    • Remove the single 9.8 mm screw next to the antenna on the back plate, using a Phillips #00 screwdriver.
  6. Palm Treo 650 Motherboard Replacement: étape 6, image 1 de 1
    • Pull the antenna outward to remove the antenna from the body of the phone.
  7. Palm Treo 650 Motherboard Replacement: étape 7, image 1 de 2 Palm Treo 650 Motherboard Replacement: étape 7, image 2 de 2
    • Pry the back cover off using an iFixit opening tool.
    • Several small clips on the inside attach to the back cover.
  8. Palm Treo 650 Motherboard Replacement, Motherboard: étape 8, image 1 de 3 Palm Treo 650 Motherboard Replacement, Motherboard: étape 8, image 2 de 3 Palm Treo 650 Motherboard Replacement, Motherboard: étape 8, image 3 de 3
    • Disconnect the ribbon cable before removing the motherboard.
    • Unclip the gray tab.
    • Pull out the orange ribbon cable.
  9. Palm Treo 650 Motherboard Replacement: étape 9, image 1 de 2 Palm Treo 650 Motherboard Replacement: étape 9, image 2 de 2
    • Pull off the motherboard.
2 autres ont terminé cette réparation.
mmedrano
Membre depuis le 11/15/09
95 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 19-3, Maness Fall 2009 Membre de l'équipe Cal Poly, Team 19-3, Maness Fall 2009
CPSU-MANESS-F09S19G3
4 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 4,279
