Aller au contenu principal
Palm Treo 755p Antenna Replacement
Ce dont vous avez besoin
  1. Palm Treo 755p Antenna Replacement, Battery: étape 1, image 1 de 3 Palm Treo 755p Antenna Replacement, Battery: étape 1, image 2 de 3 Palm Treo 755p Antenna Replacement, Battery: étape 1, image 3 de 3
    • Press the button on the back cover to release the battery cover.
    • Slide off the battery cover.
  2. Palm Treo 755p Antenna Replacement: étape 2, image 1 de 2 Palm Treo 755p Antenna Replacement: étape 2, image 2 de 2
    • Remove the battery by lifting up on one side.
  3. Palm Treo 755p Antenna Replacement, Back Cover: étape 3, image 1 de 2 Palm Treo 755p Antenna Replacement, Back Cover: étape 3, image 2 de 2
    • Remove the stylus by pulling up on the large top to reveal the top left case screw.
    • Pull away the black flap to reveal the top right case screw.
  4. Palm Treo 755p Antenna Replacement: étape 4, image 1 de 1
    • Use a T5 screwdriver to remove the five 7 mm black/red back case screws.
    • Use a T5 screwdriver to remove the middle 3.1 mm screw.
  5. Palm Treo 755p Antenna Replacement: étape 5, image 1 de 2 Palm Treo 755p Antenna Replacement: étape 5, image 2 de 2
    • Use the plastic opening tool to pry open the device. Start on the volume control side (left side of the screen) and work your way up along the edge and across the top.
    • The side volume control buttons may fall out after opening the device.
  6. Palm Treo 755p Antenna Replacement: étape 6, image 1 de 2 Palm Treo 755p Antenna Replacement: étape 6, image 2 de 2
    • Slowly unfold the back casing away from the front casing revealing the red and black wound wire speaker cable, marked by the red box.
    • Potential for device damage: Be gentle while separating the halves to prevent breaking the red and black wound wire speaker cable that bridges both halves.
  7. Palm Treo 755p Antenna Replacement: étape 7, image 1 de 3 Palm Treo 755p Antenna Replacement: étape 7, image 2 de 3 Palm Treo 755p Antenna Replacement: étape 7, image 3 de 3
    • Using tweezers, squeeze the plastic head of the black and red wound wire cable. This will detach the cable from the circuit board and fully separate the two halves.
  8. Palm Treo 755p Antenna Replacement, Antenna: étape 8, image 1 de 1
    • The antenna is on the back half of the phone.
  9. Palm Treo 755p Antenna Replacement: étape 9, image 1 de 2 Palm Treo 755p Antenna Replacement: étape 9, image 2 de 2
    • Press in the four black clips using a spudger to pop off the upper-back cover.
  10. Palm Treo 755p Antenna Replacement: étape 10, image 1 de 1
    • Lift off the top of the back cover from the phone frame.
  11. Palm Treo 755p Antenna Replacement: étape 11, image 1 de 2 Palm Treo 755p Antenna Replacement: étape 11, image 2 de 2
    • Gently pop off the antenna by pulling it away from the back cover.
Mike Shaw
Membre depuis le 01/03/11
601 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 14-6, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 14-6, Forte Winter 2011
CPSU-FORTE-W11S14G6
6 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,733
