Introduction
How to replace the keyboard on your Palm Treo Pro
Ce dont vous avez besoin
Use the Torx T5 screwdriver to remove the 5 visible 6mm screws on the back of the phone.
Use a plastic opening tool to lift the motherboard up and out of the phone case
There is a black cable under the motherboard that must be disconnected while the motherboard is still in the phone
It can easily be disconnected with your fingers
The motherboard has now been completely removed
Use the plastic opening tool to pry the side of the display glass up so you can easily remove it with your hand.
Locate the four tabs above the keyboard. The following steps will demonstrate how to remove the metal plate from the tabs, which will reveal the keyboard.
