Aller au contenu principal
Palm Vx Screen Replacement
Ce dont vous avez besoin
  1. Palm Vx Screen Replacement, Screen: étape 1, image 1 de 1
    • Take protective cover off of organizer.
    • Note: cover slides off like pointer pen.
  2. Palm Vx Screen Replacement: étape 2, image 1 de 1
    • Lay device face down on surface.
  3. Palm Vx Screen Replacement: étape 3, image 1 de 2 Palm Vx Screen Replacement: étape 3, image 2 de 2
    • Heat each side for 30 seconds individually.
    • Note: Be aware not to heat the screen, or any part to the point of damage.
    • Caution: Heating the metal case may cause burns.
  4. Palm Vx Screen Replacement: étape 4, image 1 de 3 Palm Vx Screen Replacement: étape 4, image 2 de 3 Palm Vx Screen Replacement: étape 4, image 3 de 3
    • Pry off each side individually using a plastic pry bar.
    • Note: Using a plastic pry bar will keep from damaging the case. DO NOT use a metal screwdriver or similar tool.
    • Repeat for front and back of PDA.
    • Note: Do not lose the green power button that may fall out.
  5. Palm Vx Screen Replacement: étape 5, image 1 de 1
    • Remove the screen from the plastic casing.
  6. Palm Vx Screen Replacement: étape 6, image 1 de 2 Palm Vx Screen Replacement: étape 6, image 2 de 2
    • In order to seperate the screen from the motherboard you must disconnect the ribbon attached to the screen.
    • To do this, using tweezers, flip up the cable clamp that is connecting the ribbon to the screen.
    • Once the clamp is up you can use the tweezers to gently detach the ribbon.
  7. Palm Vx Screen Replacement: étape 7, image 1 de 1
    • Now you must flip up the adjacent clamp as well, using tweezers like before.
    • After the clamp is flipped you can gently remove the second ribbon with tweezers.
  8. Palm Vx Screen Replacement: étape 8, image 1 de 1
    • Before removing the screen you must detach one more wire, the battery connector.
    • Using the tweezers, squeeze the connector attached to the wire and genlty pull.
    • Do not pull on the wire.
  9. Palm Vx Screen Replacement: étape 9, image 1 de 2 Palm Vx Screen Replacement: étape 9, image 2 de 2
    • Now that both ribbons and the wire are disconeccted, you can apply a downward pressure to the battery. You will have to carefully rotate the frame so that the battery can go through.
Will Doornink
Membre depuis le 10/04/11
11 Réputation
1 tutoriel rédigé
Équipe
UW Stout, Team 5-4, Zhou Fall 2011 Membre de l'équipe UW Stout, Team 5-4, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G4
4 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 1,914
