Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This guide is to show you how to replace the battery on Palm Zire 71.
  1. Flip the phone over
    • Flip the phone over
    • Slide the back cover upward to open
  2. Use Torx T5 screwdriver to remove the top screws
    • Use Torx T5 screwdriver to remove the top screws
  3. Remove the back sticker
    • Remove the back sticker
    • Remove the bottom Philips #00 screws
  4. Turn to the frontside Slide the screen upward a little higher WITHOUT detaching the screen
    • Turn to the frontside
    • Slide the screen upward a little higher WITHOUT detaching the screen
    • Use the plastic opening tool to pry off the front panel
  5. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  6. Remove the bottom Philips #00 screws Remove the bracket
    • Remove the bracket
    • Use the plastic opening tool to pry off the speaker
  7. Slide the back cover off Slide the back cover off
    • Slide the back cover off
  8. Remove the Philips #00 screw
    • Remove the Philips #00 screw
    • Remove the sliver metal piece
  9. Remove the Philips screws #00 Remove the rear blue panel by prying both sides using the plastic opening tool
    • Remove the Philips screws #00
    • Remove the rear blue panel by prying both sides using the plastic opening tool
  10. Remove the black plastic sticker Pull the tap up to remove the metal cap Pull the tap up to remove the metal cap
    • Remove the black plastic sticker
    • Pull the tap up to remove the metal cap
  11. Remove the cable by pinching the sides and pulling Pry off the battery with the plastic opening tool Insert the new battery
    • Remove the cable by pinching the sides and pulling
    • Pry off the battery with the plastic opening tool
    • Insert the new battery
2 autre(s) ont terminé cette réparation.
Jinxian Jiang
Membre depuis le 28/04/2011
65 Réputation
3 tutoriels rédigés
Équipe
CSU Los Angeles, Team 1-5, Nelson Spring 2011 Membre de l'équipe CSU Los Angeles, Team 1-5, Nelson Spring 2011
CSULA-NELSON-S11S1G5
3 membres
6 tutoriels rédigés
It's clear they just want you to throw it away when the battery dies. That was quite a chore getting the parts off and such without destroying the circuit board and that fine ribbon cable. Got it done though. No wifi I see. Too bad.
dnphoton - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 35
Total : 7,381
