Aller au contenu principal
Palm Zire 71 Motherboard/Screen Replacement
Ce dont vous avez besoin
  1. Palm Zire 71 Motherboard/Screen Replacement, Preparation: étape 1, image 1 de 1
    • Flip the phone so it's facing screen-side down.
    • Slide the back cover upward to open.
  2. Palm Zire 71 Motherboard/Screen Replacement, Top Screws (2) Removal: étape 2, image 1 de 1
    • Use a Torx T5 screwdriver to remove the top two screws.
  3. Palm Zire 71 Motherboard/Screen Replacement, Bottom Screws (3) Removal: étape 3, image 1 de 1
    • Remove the back sticker.
    • Remove the three bottom Phillips #00 screws.
  4. Palm Zire 71 Motherboard/Screen Replacement, Front Panel Removal: étape 4, image 1 de 2 Palm Zire 71 Motherboard/Screen Replacement, Front Panel Removal: étape 4, image 2 de 2
    • Flip the phone over so it's facing screen-side up.
    • Slide the screen upward by a few millimeters without detaching the screen.
    • Use the plastic opening tool to pry off the front panel.
  5. Palm Zire 71 Motherboard/Screen Replacement, Bracket and Speaker Removal: étape 5, image 1 de 2 Palm Zire 71 Motherboard/Screen Replacement, Bracket and Speaker Removal: étape 5, image 2 de 2
    • Remove the bottom two Phillips #00 screws.
    • Remove the bracket.
    • Use the plastic opening tool to pry off the speaker.
  6. Palm Zire 71 Motherboard/Screen Replacement, Back Cover: étape 6, image 1 de 2 Palm Zire 71 Motherboard/Screen Replacement, Back Cover: étape 6, image 2 de 2
    • Slide the back cover off.
  7. Palm Zire 71 Motherboard/Screen Replacement, Battery: étape 7, image 1 de 1
    • Remove the Philips #00 screw
    • Remove the sliver metal piece
  8. Palm Zire 71 Motherboard/Screen Replacement: étape 8, image 1 de 2 Palm Zire 71 Motherboard/Screen Replacement: étape 8, image 2 de 2
    • Remove the Philips screws #00
    • Remove the rear blue panel by prying both sides using the plastic opening tool
  9. Palm Zire 71 Motherboard/Screen Replacement: étape 9, image 1 de 3 Palm Zire 71 Motherboard/Screen Replacement: étape 9, image 2 de 3 Palm Zire 71 Motherboard/Screen Replacement: étape 9, image 3 de 3
    • Remove the black plastic sticker
    • Pull the tap up to remove the metal cap
  10. Palm Zire 71 Motherboard/Screen Replacement: étape 10, image 1 de 3 Palm Zire 71 Motherboard/Screen Replacement: étape 10, image 2 de 3 Palm Zire 71 Motherboard/Screen Replacement: étape 10, image 3 de 3
    • Remove the cable by pinching the sides and pulling
    • Pry off the battery with the plastic opening tool
    • Insert the new battery
  11. Palm Zire 71 Motherboard/Screen Replacement, Motherboard/Screen: étape 11, image 1 de 2 Palm Zire 71 Motherboard/Screen Replacement, Motherboard/Screen: étape 11, image 2 de 2
    • Remove Philips screw #00
    • Remove black plastic top part
  12. Palm Zire 71 Motherboard/Screen Replacement: étape 12, image 1 de 3 Palm Zire 71 Motherboard/Screen Replacement: étape 12, image 2 de 3 Palm Zire 71 Motherboard/Screen Replacement: étape 12, image 3 de 3
    • Pull off the orange cable
    • Now the screen and the motherboard can be separated
    • Finished
Jinxian Jiang
Membre depuis le 04/28/11
245 Réputation
3 tutoriels rédigés
Équipe
CSU Los Angeles, Team 1-5, Nelson Spring 2011 Membre de l'équipe CSU Los Angeles, Team 1-5, Nelson Spring 2011
CSULA-NELSON-S11S1G5
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 8
Total : 2,810
