Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Palm Zire m150 Headphone Jack Replacement
Ce dont vous avez besoin
  1. Palm Zire m150 Headphone Jack Replacement, Headphone Jack: étape 1, image 1 de 2 Palm Zire m150 Headphone Jack Replacement, Headphone Jack: étape 1, image 2 de 2
    • Remove cover, also known as the flap from the Palm Zire m150.
    • For the purpose of this guide and being able to see clearly, we removed the flap completely. You can keep your flap on if you wish.
  2. Palm Zire m150 Headphone Jack Replacement: étape 2, image 1 de 1
    • Remove both screws on the back.
    • Turn screw driver counterclockwise to remove screw
    • Be careful not to strip screws
  3. Palm Zire m150 Headphone Jack Replacement: étape 3, image 1 de 1
    • Remove the front part of the device from the bottom part of the device.
    • Separate front cover from back cover.
    • Be careful not to break the connector that connects the screen to motherboard.
  4. Palm Zire m150 Headphone Jack Replacement: étape 4, image 1 de 2 Palm Zire m150 Headphone Jack Replacement: étape 4, image 2 de 2
    • Insert NEW audio piece into the top case housing.
    • On the NEW audio piece, use a soldering iron to solder.
    • Let solder cool before reassembling unit.
    • Soldering iron needs time to warm up in order for use
Kate
Membre depuis le 01/26/16
528 Réputation
5 tutoriels rédigés
Équipe
USF Sarasota-Manatee, Team 1-3, Stewart Spring 2016 Membre de l'équipe USF Sarasota-Manatee, Team 1-3, Stewart Spring 2016
USFSM-STEWART-S16S1G3
5 membres
7 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 11
Total : 517
