Introduction
This guide will provide instructions and visuals on how to replace the display screen.
Pièces
Aucune pièce nécessaire.
  1. Remove the batteries.
    • Remove the batteries.
  2. Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
    • Using a Torx 5 screwdriver, remove the four screws located on the rear cover of the device by turning counterclockwise. Set aside screws.
  3. Remove rear cover by gently lifting it up from the bottom.
    • Remove rear cover by gently lifting it up from the bottom.
  4. Carefully lift up the circuit board, which will also lift up the screen. Do so carefully to prevent breaking the connectors.
    • Carefully lift up the circuit board, which will also lift up the screen. Do so carefully to prevent breaking the connectors.
  5. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
    Vous avez déjà réparé quelque chose ? Vous êtes un génie.
    Partagez votre réparation avec le hashtag #ImAGenius
    Nous sommes tous des génies
    • Lift the left side of the circuit board and open it as though it were a book.
  6. Unplug the three connectors located on the right side of the circuit board with great caution and care. Do not pull by the cable, and be sure to pull the connector itself gently.
    • Unplug the three connectors located on the right side of the circuit board with great caution and care. Do not pull by the cable, and be sure to pull the connector itself gently.
    • After separating the screen from the board, set aside the old display screen.
    • Replace with a new display screen.
  7. Plug in the three connectors.
    • Plug in the three connectors.
  8. Close again like a book, and lay it gently into the front panel, screen facing outwards of the front panel.
    • Close again like a book, and lay it gently into the front panel, screen facing outwards of the front panel.
  9. Put the back cover on the device and screw the four screws, screwing in a clockwise direction.  Take caution not to over-tighten the screws.
    • Put the back cover on the device and screw the four screws, screwing in a clockwise direction. Take caution not to over-tighten the screws.
Lexi Gallucci
Membre depuis le 18/10/2011
11 Réputation
2 tutoriels rédigés
Équipe
James Madison, Team 1-3, Allen Fall 2011 Membre de l'équipe James Madison, Team 1-3, Allen Fall 2011
JMU-ALLEN-F11S1G3
5 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 513
