Aller au contenu principal
Palm m105 Motherboard Replacement
Ce dont vous avez besoin
  1. Palm m105 Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Start with your intact Palm m105.
  2. Palm m105 Motherboard Replacement: étape 2, image 1 de 1
    • Remove protective flap by pulling directly out from the top.
    • The two clips will pop out
  3. Palm m105 Motherboard Replacement: étape 3, image 1 de 1
    • Remove Faceplate. There is a tab where the finger is located in the picture that needs to be pulled up.
    • The Faceplate will then easily lift off
  4. Palm m105 Motherboard Replacement: étape 4, image 1 de 2 Palm m105 Motherboard Replacement: étape 4, image 2 de 2
    • Using a T5 Torx bit screwdriver, remove the four screws located on the back of the device turning counter clockwise.
    • The link to purchase this screwdriver is Located here.
  5. Palm m105 Motherboard Replacement: étape 5, image 1 de 1
    • This is what the device looks like once you have taken the screws out and opened the device.
  6. Palm m105 Motherboard Replacement: étape 6, image 1 de 1
    • The Motherboard and screen will pop out of the back case easily.
    • Be careful when doing this step, the components are fragile.
  7. Palm m105 Motherboard Replacement: étape 7, image 1 de 1
    • To remove the screen from the motherboard there are going to be three tabs that need to pulled up.
    • ** This step needs to be done with special care because it is very fragile.**
    • Once they are all three popped up the motherboard and screen will separate easily.
  8. Palm m105 Motherboard Replacement: étape 8, image 1 de 1
Aaron
Membre depuis le 10/04/11
7 Réputation
1 tutoriel rédigé
Équipe
UW Stout, Team 1-3, Zhou Fall 2011 Membre de l'équipe UW Stout, Team 1-3, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G3
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 15
Total : 1,068
