Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
How remove the outer casing
Pièces
Aucune pièce spécifiée.
  1. Lay device face down on surface.
    • Lay device face down on surface.
  2. Heat the left and top edges with hairdryer for one minute. Move hairdryer back and forth to evenly heat up surface.
    • Heat the left and top edges with hairdryer for one minute.
    • Move hairdryer back and forth to evenly heat up surface.
    • Caution: directly heating the screen can melt or distort the screen.
  3. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  4. Use tweezers to hold Palm right side down on it's side.
    • Use tweezers to hold Palm right side down on it's side.
    • Use a plastic opening tool to pry open front and back casing.
    • If you are unable to open you may need to heat with hairdryer for longer.
    • Be sure not to touch case directly with fingers, it will be hot!
  5. Leave plastic opening tools in between front and back casing.
    • Leave plastic opening tools in between front and back casing.
    • Rotate Palm and repeat steps 2 and 3 for right and back edges.
  6. Now pry open front and back casing with plastic opening tools. Separate front and back casing completely. Power button will fall off once front and back casing have been removed. Be sure not to lose it.
    • Now pry open front and back casing with plastic opening tools.
    • Separate front and back casing completely.
    • Power button will fall off once front and back casing have been removed. Be sure not to lose it.
Ligne d'arrivée
Anthony Platt
Membre depuis le 09/02/2010
66 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 13-25, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 13-25, Maness Winter 2010
CPSU-MANESS-W10S13G25
4 membres
4 tutoriels rédigés
So...This given by my grandmother and it is out of battery. Unluckily, it won't charge, because the %#*@ old battery had gone kaput. I had a hard time finding one that might be suitable, and turnout that I need to insert it into the device and connect it to the circuit board. I have some solid soldering skills, but without a heat gun, the andonized cover won't come off. And what's more, I jammed a pencil tip into the "reset" hole when trying to reset the device. Thinking the big opening was a kind of cover-releasing button...I was just having a whole lot of trouble and thinking too much. !&&*.
Xavier Jiang - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 1,399
