Aller au contenu principal
Panasonic CF-31 Toughbook Keyboard Replacement
Ce dont vous avez besoin
  1. Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: étape 1, image 1 de 3 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: étape 1, image 2 de 3 Panasonic CF-31 Toughbook  Keyboard  Replacement, Keyboard: étape 1, image 3 de 3
    • Open the battery compartment by pulling the tab forward and then down.
    • Open the compartment door by pushing down.
    • Use the plastic tab to pull the battery out of the compartment.
  2. Panasonic CF-31 Toughbook  Keyboard  Replacement: étape 2, image 1 de 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: étape 2, image 2 de 2
    • Use a Phillips #2 screwdriver to remove the three screws from the bezel.
    • Use a nylon spudger to remove the bezel.
  3. Panasonic CF-31 Toughbook  Keyboard  Replacement: étape 3, image 1 de 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: étape 3, image 2 de 2
    • Use a nylon spudger to lift each corner of the keyboard.
    • Use your hands and gently pull back to remove the keyboard.
  4. Panasonic CF-31 Toughbook  Keyboard  Replacement: étape 4, image 1 de 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: étape 4, image 2 de 2
    • Use a Phillips # 2 screwdriver to remove the four screws securing the keyboard shield.
    • Remove the keyboard shield.
  5. Panasonic CF-31 Toughbook  Keyboard  Replacement: étape 5, image 1 de 1
    • Remove the top left ribbon cable using a nylon spudger to pull the top and bottom tabs right.
  6. Panasonic CF-31 Toughbook  Keyboard  Replacement: étape 6, image 1 de 1
    • Remove the top right ribbon cable using a nylon spudger and push the top and bottom tabs left.
  7. Panasonic CF-31 Toughbook  Keyboard  Replacement: étape 7, image 1 de 2 Panasonic CF-31 Toughbook  Keyboard  Replacement: étape 7, image 2 de 2
    • Remove the bottom left ribbon cable using a nylon spudger and push the top and bottom tabs right.
To reassemble the Panasonic CF-31 Toughbook Laptop, follow these instructions in reverse order.
Richard Gill
Membre depuis le 01/16/19
145 Réputation
1 tutoriel rédigé
Équipe
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019 Membre de l'équipe USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019
USFSM-STEWART-S19S1G1
18 membres
29 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 19
Total : 2,717
