Introduction
Be sure to remove the battery and SD card before opening the camera to get to the logic board, flash, or lens. The logic board and flash must be removed to access the lens component.
Ce dont vous avez besoin
Remove the piece of the frame that covers the camera's function buttons by pulling upwards from the end, as shown in the picture.
It may feel like you are breaking the camera, since the frame makes a snapping sound as you remove it. However, as long as you are careful to remove the frames individually as shown, the frames will probably not break.
Turn the camera and remove the frame from the opposite side of the camera by pulling from either the top or the bottom in an outwards direction.
As in the previous step, it may seem like you are breaking the camera, because the frame makes snapping noises, as you pull it apart.This is to be expected, and will not harm the camera.
Remove the top piece of the casing from the camera, as shown in the picture.
Press in the "realease" tab to rotate the lens and screen 90 degrees.
Remove the two screws(from left to right; 5.23mm Philips, 2.1mm Philips) indicated.
Flip the camera over 180 degrees and remove the same screws that are on the other side.
