Aller au contenu principal
Panasonic D-snap SV-AV50 Screen Replacement
Ce dont vous avez besoin
  1. Panasonic D-snap SV-AV50 Screen Replacement, Screen: étape 1, image 1 de 1
    • Open and rotate the screen, then remove the screw(3.5mm Philips) indicated with a screwdriver.
    • Then, rotate the screen 180 degrees and remove the screw on the opposite side.
  2. Panasonic D-snap SV-AV50 Screen Replacement: étape 2, image 1 de 1
    • Remove the screw(2.6mm Philips) indicated on the top of the screen with the screwdriver. Then remove the corresponding screw on the bottom of the screen.
  3. Panasonic D-snap SV-AV50 Screen Replacement: étape 3, image 1 de 1
    • Pull the backing away from the screen as shown in the photo.
  4. Panasonic D-snap SV-AV50 Screen Replacement: étape 4, image 1 de 1
    Outil utilisé dans cette étape :
    • Unplug the black connector between the camera and the screen by pulling down.
    • For increased ease, use tweezers or forceps, as seen in the picture
  5. Panasonic D-snap SV-AV50 Screen Replacement: étape 5, image 1 de 1
    • Pull the screen away from the camera the same way that you removed the screen backing.
  6. Panasonic D-snap SV-AV50 Screen Replacement: étape 6, image 1 de 1
    • Use the screwdriver to remove the screw(2.46mm Philips) indicated.
  7. Panasonic D-snap SV-AV50 Screen Replacement: étape 7, image 1 de 1
    • Pull upwards on the screen border to remove it from the actual screen.
Zoe Hinck
Membre depuis le 04/12/12
29 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 6-19, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 6-19, Amido Spring 2012
CPSU-AMIDO-S12S6G19
3 membres
12 tutoriels rédigés
1 commentaire de tutoriel
I need the LCD screen, can you helpme?
leon - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 7
Total : 1,142
