Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Panasonic DECT 6.0 Button Replacement
Ce dont vous avez besoin
  1. Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: étape 1, image 1 de 3 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: étape 1, image 2 de 3 Panasonic DECT  6.0 Button Replacement, Jammed/Broken Buttons: étape 1, image 3 de 3
    • Remove the battery cover by pushing the tab upwards and sliding it off.
    • Pull out the battery/energy source from its slot.
    • Keep all pieces in a safe and orderly manner for ease of reassembly.
    Demander à FixBot
  2. Panasonic DECT  6.0 Button Replacement: étape 2, image 1 de 3 Panasonic DECT  6.0 Button Replacement: étape 2, image 2 de 3 Panasonic DECT  6.0 Button Replacement: étape 2, image 3 de 3
    • Unscrew the screws you see on the inside of the casing using an appropriate screwdriver from the JIS Driver Set.
    • Carefully pry each side open with the iFixit Opening tool.
    • Detach the back of the phone case.
    Demander à FixBot
  3. Panasonic DECT  6.0 Button Replacement: étape 3, image 1 de 3 Panasonic DECT  6.0 Button Replacement: étape 3, image 2 de 3 Panasonic DECT  6.0 Button Replacement: étape 3, image 3 de 3
    • Unscrew the screws to remove the motherboard using an appropriate screwdriver from the JIS Driver Set.
    • Potential for device damage
    Demander à FixBot
  4. Panasonic DECT  6.0 Button Replacement: étape 4, image 1 de 3 Panasonic DECT  6.0 Button Replacement: étape 4, image 2 de 3 Panasonic DECT  6.0 Button Replacement: étape 4, image 3 de 3
    • Carefully pull off the circuitry and cords from the front half of the phone and set them aside.
    • Bring the buttons to the front.
    Demander à FixBot
  5. Panasonic DECT  6.0 Button Replacement: étape 5, image 1 de 2 Panasonic DECT  6.0 Button Replacement: étape 5, image 2 de 2
    • Pull gently to separate the button pad from the phone cover.
    • Identify the broken/jammed button you were having issues with.
    • Replace or return the button to its function.
    Demander à FixBot
Jacob
Membre depuis le 05/31/16
131 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 46
Total : 886
