Aller au contenu principal
Panasonic DMP-BD89 Wifi Board Replacement
Ce dont vous avez besoin
  1. Panasonic DMP-BD89 Wifi Board Replacement, Disk Tray Cover: étape 1, image 1 de 2 Panasonic DMP-BD89 Wifi Board Replacement, Disk Tray Cover: étape 1, image 2 de 2
    • First, before powering off, press the eject button to open the tray.
  2. Panasonic DMP-BD89 Wifi Board Replacement: étape 2, image 1 de 3 Panasonic DMP-BD89 Wifi Board Replacement: étape 2, image 2 de 3 Panasonic DMP-BD89 Wifi Board Replacement: étape 2, image 3 de 3
    • Remove the front cover of the tray.
    • Do so by gently pushing it out, away from the player, ensuring the pictured tabs clear the tray.
    • Then slide it vertically up and away.
  3. Panasonic DMP-BD89 Wifi Board Replacement: étape 3, image 1 de 2 Panasonic DMP-BD89 Wifi Board Replacement: étape 3, image 2 de 2
    • Press eject button to close the tray.
    • Make sure to unpower and unplug device before continue work on other fixes.
  4. Panasonic DMP-BD89 Wifi Board Replacement, Exterior Cover: étape 4, image 1 de 2 Panasonic DMP-BD89 Wifi Board Replacement, Exterior Cover: étape 4, image 2 de 2
    • Using a Phillips #1 screwdriver, unscrew the back three screws.
  5. Panasonic DMP-BD89 Wifi Board Replacement: étape 5, image 1 de 1
    • Slide the top panel horizontally to remove it.
  6. Panasonic DMP-BD89 Wifi Board Replacement: étape 6, image 1 de 3 Panasonic DMP-BD89 Wifi Board Replacement: étape 6, image 2 de 3 Panasonic DMP-BD89 Wifi Board Replacement: étape 6, image 3 de 3
    • Locate 6 tabs across the device.
    • 2 are on the bottom, 1 is on the left and right, and 2 are are on the inside.
  7. Panasonic DMP-BD89 Wifi Board Replacement: étape 7, image 1 de 1
    • Pop the 6 markers out.
    • Then take off the cover.
  8. Panasonic DMP-BD89 Wifi Board Replacement, Wifi Board: étape 8, image 1 de 2 Panasonic DMP-BD89 Wifi Board Replacement, Wifi Board: étape 8, image 2 de 2
    • Locate reddish brown cable. Detach from green circuit board by pulling upward.
  9. Panasonic DMP-BD89 Wifi Board Replacement: étape 9, image 1 de 1
    • Using tweezer, compress the white knob holding the wifi module board in place.
  10. Panasonic DMP-BD89 Wifi Board Replacement: étape 10, image 1 de 2 Panasonic DMP-BD89 Wifi Board Replacement: étape 10, image 2 de 2
    • Pull the module board straight up, removing completely. The second photo is how your device should look with the WiFi board removed.
Mohan Saxena
Membre depuis le 10/17/17
133 Réputation
1 tutoriel rédigé
Équipe
UC Santa Barbara, Team S2-G9, Weedon Fall 2017 Membre de l'équipe UC Santa Barbara, Team S2-G9, Weedon Fall 2017
UCSB-WEEDON-F17S2G9
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 385
