Ce dont vous avez besoin
Eject the disk tray from the DVD player before removing power supply.
Remove the three screws running along the back edge of case cover.
Remove the two screws from each side of the case cover.
Lift up the five tabs securing the front panel to the chassis. There are three on the bottom, and two on the inside edges of the panel. Panel should then lift off the player.
Be careful not to disturb the electrical connectors on the circuit board.
Locate the four screws securing the disk drive assembly. There are two on each side.
Use a narrow screwdriver to remove all four screws.
Remove the blue ribbon wire from its connector. When doing this, be cautious to not damage the connector.
Grasp the bridge above the wheel and push the tabs on the side as shown.
Pull down firmly and away from the laser housing.
Remember the tray position,if it is not on the guide rollers in the same position it will not open and close properly and you will have to dismantle it again to get in at the right position. As I had too!!!
3 autres ont terminé cette réparation.
