Aller au contenu principal
Panasonic ER-GN30-K Motor Replacement
Ce dont vous avez besoin
  1. Panasonic ER-GN30-K Motor Replacement, Motor: étape 1, image 1 de 1
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Replacement: étape 2, image 1 de 1
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Replacement: étape 3, image 1 de 1
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Replacement: étape 4, image 1 de 1
    • Use a metal spudger to pry apart the silver plastic case.
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Replacement: étape 5, image 1 de 1
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Replacement: étape 6, image 1 de 1
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Replacement: étape 7, image 1 de 2 Panasonic ER-GN30-K Motor Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
  8. Panasonic ER-GN30-K Motor Replacement: étape 8, image 1 de 1
    • Remove the motor from the case by sliding the cover off of it.
6 autres ont terminé cette réparation.
Corey Tappan
Membre depuis le 08/27/15
209 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 15-3, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 15-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G3
4 membres
5 tutoriels rédigés
Un commentaire
My motor working intermittently. Took apart per instruction (very detailed, thank you). Everything loos good on the internals. I think my problem is succumb build up on the negative spring where it makes contact on negative end of battery. I scrapped it a little with tip of knife, working some what better. Need to find small wire brush to get in there and give it a good cleaning. Thank you for your guide :)
Rocko the fixit cat - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 42
Total : 3,564
