Aller au contenu principal
Panasonic ER-GN30-K Motor Shaft Replacement
Ce dont vous avez besoin
  1. Panasonic ER-GN30-K Motor Shaft Replacement, Motor Shaft: étape 1, image 1 de 1
    • Remove the dark transparent cap by gently pulling on it.
  2. Panasonic ER-GN30-K Motor Shaft Replacement: étape 2, image 1 de 1
    • Remove the back battery cap from the device by twisting it to the unlock position and pulling.
  3. Panasonic ER-GN30-K Motor Shaft Replacement: étape 3, image 1 de 1
    • Remove the black trimmer cap from the top of the device by gently pulling it.
  4. Panasonic ER-GN30-K Motor Shaft Replacement: étape 4, image 1 de 1
    • The motor shaft should be sticking out from the top of the device.
    • Use the metal prying tool to pry apart the silver plastic case .
    • Pull each side of the plastic case off.
  5. Panasonic ER-GN30-K Motor Shaft Replacement: étape 5, image 1 de 1
    • Unscrew one 20mm Phillips #00 screw.
  6. Panasonic ER-GN30-K Motor Shaft Replacement: étape 6, image 1 de 1
    • Remove the rubber stopper from the top of the motor shaft by gently pulling it off.
  7. Panasonic ER-GN30-K Motor Shaft Replacement: étape 7, image 1 de 2 Panasonic ER-GN30-K Motor Shaft Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use a pair of tweezers to remove the plastic cover of the motor shaft by pulling it away from the motor.
Alejandro Garabatos
Membre depuis le 09/03/15
330 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 15-3, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 15-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S15G3
4 membres
5 tutoriels rédigés
2 commentaires
Thank you, small parts where switch is could be shown as well. Would be very helpful.
Advise for putting things back together: remove plastic switch cover and put back only after full reassembly
Aurimas Miko - Réponse
Dear Alejandro,
thank You for your instruction, my question is where this motor shaft part is available? I can’t find it anywhere on the net. Thanks if you can help. Bence Fazekas
fazebence - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 18
Total : 1,609
