Aller au contenu principal
Panasonic ES-RF31 Battery Replacement
Ce dont vous avez besoin
  1. Panasonic ES-RF31 Battery Replacement, Battery: étape 1, image 1 de 3 Panasonic ES-RF31 Battery Replacement, Battery: étape 1, image 2 de 3 Panasonic ES-RF31 Battery Replacement, Battery: étape 1, image 3 de 3
    • Loose the screw at the bottom part of the razor
  2. Panasonic ES-RF31 Battery Replacement, Removing the Backcover: étape 2, image 1 de 3 Panasonic ES-RF31 Battery Replacement, Removing the Backcover: étape 2, image 2 de 3 Panasonic ES-RF31 Battery Replacement, Removing the Backcover: étape 2, image 3 de 3
    • Slide the cover from top to bottom
  3. Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: étape 3, image 1 de 2 Panasonic ES-RF31 Battery Replacement, Removing the Batterycover: étape 3, image 2 de 2
    • Loosen these eight screws
  4. Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: étape 4, image 1 de 2 Panasonic ES-RF31 Battery Replacement, Removing the Battery Cover: étape 4, image 2 de 2
    • Insert an opening tool into the gap
    • Gently remove the battery cover
  5. Panasonic ES-RF31 Battery Replacement, Removing the Battery: étape 5, image 1 de 2 Panasonic ES-RF31 Battery Replacement, Removing the Battery: étape 5, image 2 de 2
7 autres ont terminé cette réparation.
Daniel
Membre depuis le 07/06/15
934 Réputation
2 tutoriels rédigés
Équipe
iFixit EU Team Membre de l'équipe iFixit EU Team
Staff
44 membres
1 110 tutoriels rédigés
4 commentaires
Thanks Daniel,
I followed your instructions and all went well. One thing to add: after re-assembly of the (loaded) battery my razor would not turn on. At first I thought of a bad contact, but it turned out that the razor needed a few minutes plugged into the power supply. After that it worked fine. I suspect, that the load-control hardware needs the external power to reset itself.
Cheers, Nils
Nils Kay - Réponse
Hello Nils!
Thanks for the hint.
Glad to hear that your razor works again!
Greetings
Daniel - Réponse
Daniel, thank you very much for instruction.
Unfortunetly, into shaver I found only 1 battery.
Because used 3.7 v element, I prepared 2 x 1.2 v batteries.
Виктор Богачёв - Réponse
My razor was the Panasonic ES8103S and the disassembly process was similar. From the pictures above, the battery looks the same. My razor actually had a piece under the slide-off cover that was totally rusted so I will just buy a new one on Amazon for $50. For future reference, I would like to know where you get the replacement battery? There is no model number on the battery and I couldn’t find any info online.
David Paul - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 72
Total : 6,043
