Aller au contenu principal
Panasonic HDC-TM90 LCD Screen Replacement
Ce dont vous avez besoin
  1. Panasonic HDC-TM90 LCD Screen Replacement, Battery: étape 1, image 1 de 1
    • Open the LCD screen.
  2. Panasonic HDC-TM90 LCD Screen Replacement: étape 2, image 1 de 1
    • Slide the battery release switch away from the battery.
  3. Panasonic HDC-TM90 LCD Screen Replacement: étape 3, image 1 de 1
    • While holding the switch away from the battery, push the battery out of the slot.
  4. Panasonic HDC-TM90 LCD Screen Replacement: étape 4, image 1 de 1
    • Remove the battery from the camera.
  5. Panasonic HDC-TM90 LCD Screen Replacement, Panasonic HDC-TM90 Lens Clean: étape 5, image 1 de 3 Panasonic HDC-TM90 LCD Screen Replacement, Panasonic HDC-TM90 Lens Clean: étape 5, image 2 de 3 Panasonic HDC-TM90 LCD Screen Replacement, Panasonic HDC-TM90 Lens Clean: étape 5, image 3 de 3
    • Remove 5 screws from the side panel body of the camcorder.
    • Use the spudger to remove the top of the camcorder.
  6. Panasonic HDC-TM90 LCD Screen Replacement: étape 6, image 1 de 2 Panasonic HDC-TM90 LCD Screen Replacement: étape 6, image 2 de 2
    • Unscrew three screws to remove the lens rim on the front of the camcorder.
    • Be aware of the wires attaching the lens rim to the body of the camcorder. You will not be able to separate the lens rim completely.
    • Use caution when separating the shutter lever.
  7. Panasonic HDC-TM90 LCD Screen Replacement: étape 7, image 1 de 1
    • Remove the rubber ring around the lens.
  8. Panasonic HDC-TM90 LCD Screen Replacement: étape 8, image 1 de 1
    • Unscrew the lens by removing the three screws connected to it.
  9. Panasonic HDC-TM90 LCD Screen Replacement, LCD Screen: étape 9, image 1 de 2 Panasonic HDC-TM90 LCD Screen Replacement, LCD Screen: étape 9, image 2 de 2
    • Remove the side panel of the camcorder.
    • Remove the top panel of the camcorder.
    • For help with this step see prerequisite guide: Lens Clean.
  10. Panasonic HDC-TM90 LCD Screen Replacement: étape 10, image 1 de 1
    • Open camcorder screen.
  11. Panasonic HDC-TM90 LCD Screen Replacement: étape 11, image 1 de 1
    • Turn the LCD screen perpendicular to the camcorder.
    • Remove the screws.
    • Have caution when you remove the screen. There is a wire connecting it to the rest of the camera that should not be detached.
  12. Panasonic HDC-TM90 LCD Screen Replacement: étape 12, image 1 de 1
    • Carefully pry the plastic backing on the screen using a metal spudger.
  13. Panasonic HDC-TM90 LCD Screen Replacement: étape 13, image 1 de 2 Panasonic HDC-TM90 LCD Screen Replacement: étape 13, image 2 de 2
    • Peel back the black tape holding the wire strip to the camcorder screen.
    • Unclip the small latch from the wire strip.
  14. Panasonic HDC-TM90 LCD Screen Replacement: étape 14, image 1 de 1
    • Remove the screws from the metal frame.
    • Be careful when holding the screen after the frame has been unscrewed. The screen and all of its components are unattached and can fall apart.
BayleeVersteeg
Membre depuis le 01/30/17
37 Réputation
2 tutoriels rédigés
Équipe
Baylor, Team 8-4, Whitney Spring 2017 Membre de l'équipe Baylor, Team 8-4, Whitney Spring 2017
BU-WHITNEY-S17S8G4
3 membres
5 tutoriels rédigés
Un commentaire
Steps 1-4 are good pre-reqs.
Are all of steps 5-8 absolutely necessary for LCD screen replacement?
Step 9-bullet 3: Change to 'note' rather than bullet point and put it first.
Step 11-bullet 2: List the # of screws to be removed and with what screwdriver. Show 2nd picture of screws to remove on actual LCD door.
Step 11-bullet 3: Change to a "caution" rather than just a bullet. Also we had a spring fall out at this step with no idea where it came from. Perhaps you could address this.
Step 12- We actually had to use a 2nd spudger to pry it apart. One as a wedge and one as a lever to separate.
Step 14-bullet 2: change to a "Warning" symbol.
Seems to be an incomplete guide, as the LCD screen is still affixed to the device.
Rene Klopf - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 590
