Aller au contenu principal
Introduction
Once the back cover has been removed, removing the antenna is as simple as unscrewing one screw.
Pièces
Aucune pièce spécifiée.
  1. Orient the phone so that the phone model and other descriptive information is facing upward. Locate the two silver screws near the hinge where the battery is housed.
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Pull off the back panel of the phone. Make sure you pull the cover off carefully in order to prevent damage to the back cover. Make sure you pull the cover off carefully in order to prevent damage to the back cover.
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
  3. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  4. Find the silver screw located in the red circle. Using a Philips head #2 screwdriver, remove the screw holding the antenna in place.
    • Find the silver screw located in the red circle.
    • Using a Philips head #2 screwdriver, remove the screw holding the antenna in place.
  5. Press the release button. The release button is located in the red circle in the image to the left.
    • Press the release button.
    • The release button is located in the red circle in the image to the left.
Elizabeth Kelly
Membre depuis le 22/10/2012
501 Réputation
5 tutoriels rédigés
Équipe
Clemson, Team 15-1, Benson Fall 2012 Membre de l'équipe Clemson, Team 15-1, Benson Fall 2012
CLEM-BENSON-F12S15G1
4 membres
10 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 1,380
