Introduction
I needed to convert my camera to full spectrum so I went about it. Since most of the camera needs to be disassembled to reach the filter, I posted this as a disassembly guide, which can be developed further by other community members. The stabilization unit removal is also shown even though it is not needed for the filter removal.
Ce dont vous avez besoin
Photo 1: Remove the 7 mm screw (red) on the right side of the grip, as well as the 4 mm screw (orange) below the SD compartment door.
Photo 2: Remove the 4mm screw on the left side of the camera (red) above the LCD hinge, as well as the 4mm screw above the USB port (orange)
Photo 3: Remove all 5 mm screws circled in red, as well as the 4 mm screw (orange) and another 5 mm screw with a wider thread (yellow)
Outil utilisé dans cette étape :Heavy-Duty Spudger$4.99
Photo 1: Remove the two 2 mm screws below the viewfinder eyecup
Then, remove the viewfinder cup with a heavy duty spudger from below.
Photo 2: Remove the two 6 mm screws (red) and the two 4 mm screws of the metal plate that is holding the back panel against the viewfinder.
Photo 1: You can start lifting the rubber corner of the thumb rest close to the back control dial.
Photo 2: Lift the thumb rest with your nails or a spudger.
Photo 1: remove 5mm screw marked in red square
Photo 2: a last 5 mm screw sits under the rubber grip near the base of the camera
Photo 3: now the back panel can be removed
Photo 1: Disconnect all visible ribbon cables, remove two 3 mm screws (red) at the left side of the PCB and two 5 mm screws (orange) at the right side of the PCB
Photo 2: View with all four screws and 11 ribbon cables disconnected
Photo 3: Pull the main PCB out to the lower right corner
Photo 1: Remove the 4 mm screw beneath the rubber below the left strap lug
Photo 2: Remove the other 4 mm screw beneath the rubber below the G logo
Photo 3: Remove the 7 mm screw beneath the rubber below the shutter release
Photo 1: Remove the 3 mm screw that is constraining the flash hinge movement.
Photo 2: Now hold the flash back to access a screw within the flash housing.
Photo 3: The top panel can now be removed by pulling it up.
Photo 1: Remove 4 mm screw holding the plastic plate above the flash batteries
Photo 2: Remove a 5 mm screw holding the plastic plate
Photo 3: the rest of the flash assembly can come off now
Photo 1: Remove the 3 mm screw in the lower left corner
Photo 2: Remove the 2 mm screw in the upper left corner
Photo 3: The metal plate can now be pulled out
Photo 1: Take a picture of the position of the sensor assembly relative to the metal nub
Photo 2: remove three 7 mm screws that are holding the sensor assembly to the magnesium alloy front plate (one is hidden behind the ribbon cable)
Finally, pull out the sensor assembly
Photo 1: Remove the three screws marked in red
Photo 3: lift the metal cage holding the filters.
Photo 1: There is a thin glass plate with a red tint glued tightly onto the metal frame. Below it is a thick bluish glass plate held within a rubber frame
Both glass elements filter infrared. Removing the reddish glass plate resulted in some infrared sensitivity, and removing the second one gives most infrared sensitivity
Photo 2: close-up of the bluish filter
Photo 3: breakdown of the blue filter assembly in layering order
Photo 1: Remove the three 4 mm screws marked in orange
Photo 2: Lift up the C-shaped metal plate and disconnect the two ribbon cables
Photo 2: You can now pull out the sensor PCB from the stabilization unit
Photo 2: Close-up of the beads held inside the bluish filter, on which the sensor PCB rests to freely move.
5 autres ont terminé cette réparation.
7 commentaires de tutoriel
Can i e-mail you?
Fair warning — I bricked my camera following these instructions. Error message is “ please turn camera off and then on again” Only part I wasn’t sure of was to put back the UV filter housing in, which I didn’t because it didn’t want to fit without the filter. Maybe I ripped out a cable or something?
Hello,
N° 12, you forget a screw in the center ! ;)
Thanks for the guide Kevin, was very helpful!
my man, i want to ask you something, the sensor in my g81 is not aligned INSIDE the ibis unit, by that i mean that the ibis is well centred but not the sensor, is there any solutions rather than opening the hell out of my camera to re aligne it ? i can send pictures, thanks
