Aller au contenu principal
Panasonic Lumix DMC-F7 Back Case Replacement
Ce dont vous avez besoin
  1. Panasonic Lumix DMC-F7 Back Case Replacement, Battery: étape 1, image 1 de 1
    • Slide the lock switch to the right so that it is in the unlocked position.
    • Use your finger to slide the battery hatch in the direction of the downward arrow so that the hatch is open.
    • Both battery and memory card should now be visible.
  2. Panasonic Lumix DMC-F7 Back Case Replacement: étape 2, image 1 de 1
    • Open the battery hatch and then the black cover to expose the battery compartment.
    • The camera used to create these repair guides did not have a battery and memory card.
    • Remove the battery.
    • When installing the new battery, ensure it is in the same orientation as before.
  3. Panasonic Lumix DMC-F7 Back Case Replacement, Back Case: étape 3, image 1 de 1
    • Using the Phillips #00 screwdriver, remove the two 2.8 mm screws located under the hatch.
  4. Panasonic Lumix DMC-F7 Back Case Replacement: étape 4, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the three 2.8 mm screws on the bottom of the camera.
  5. Panasonic Lumix DMC-F7 Back Case Replacement: étape 5, image 1 de 1
    • Use the Phillips #00 screwdriver to remove the two 2.8 mm screws on the side of the camera.
  6. Panasonic Lumix DMC-F7 Back Case Replacement: étape 6, image 1 de 2 Panasonic Lumix DMC-F7 Back Case Replacement: étape 6, image 2 de 2
    • Use a spudger to pry open the case at all sides.
  7. Panasonic Lumix DMC-F7 Back Case Replacement: étape 7, image 1 de 2 Panasonic Lumix DMC-F7 Back Case Replacement: étape 7, image 2 de 2
    • Be careful not to damage the ribbon cable when opening. Ensure it is still attached.
    • Use your fingers to carefully remove the back casing from the front of the camera.
  8. Panasonic Lumix DMC-F7 Back Case Replacement: étape 8, image 1 de 1
    • Place the camera on a flat surface with the front side facing down.
    • Use the spudger to flip up the retaining flap and slide the ribbon cable out of the connector.
    • Hold down on the camera's metal casing with one hand. Using your other hand, remove the back case from the rest of the camera.
Alex Penman
Membre depuis le 01/28/11
463 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 7-35, Regan Winter 2011 Membre de l'équipe Cal Poly, Team 7-35, Regan Winter 2011
CPSU-REGAN-W11S7G35
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 931
