Introduction
This guide shows how to remove the LCD screen from the circuit board and replace it.
Outils
Pièces
Aucune pièce spécifiée.
Locate the memory card and battery card latch on the bottom of the camera.
Slide the latch to the open position.
Using a size #00 Phillips screwdriver, remove the three 4.58 mm screws on the bottom of the camera.
Use this screwdriver for all screws in the device.
Gently lift up the LCD screen.
Using a plastic prying tool, flip up the latch that holds the thin ribbon in place.
It should fall out on its own or with a gentle tug.
3 autre(s) ont terminé cette réparation.
