Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide will show you how to remove the back panel of your camera.
Pièces
Aucune pièce spécifiée.
  1. Move the switch on the battery door to the Open position.
    • Move the switch on the battery door to the Open position.
    • The door will automatically swing open after you let it go.
  2. Push the small gray tab on the top right corner to the left. The battery will pop out slightly. Keep your finger clear of the battery when it pops out.
    • Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
    • Keep your finger clear of the battery when it pops out.
  3. Push the memory card in and let go.
    • Push the memory card in and let go.
    • The memory card will pop out slightly.
    • Pull out the memory card.
  4. Unscrew the small screws on the sides of the camera. The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
    • Unscrew the small screws on the sides of the camera.
    • The screws on the left side(#00P, 4.7mm) are longer than the screw on the right side(#00P, 3.3mm).
  5. Unscrew the three small screws on the bottom(#00P, 3.3mm). The bottom will fall off.
    • Unscrew the three small screws on the bottom(#00P, 3.3mm).
    • The bottom will fall off.
  6. Lift up the bottom back cover by prying the bottom edge with the spudger. Gently lift up the back cover with your hand from the bottom to the top. Gently lift up the back cover with your hand from the bottom to the top.
    • Lift up the bottom back cover by prying the bottom edge with the spudger.
    • Gently lift up the back cover with your hand from the bottom to the top.
  7. Lift the tabs on the ZIF connectors. The ribbon cables should easily come out of the ZIF connectors. The ribbon cables should easily come out of the ZIF connectors.
    • Lift the tabs on the ZIF connectors.
    • The ribbon cables should easily come out of the ZIF connectors.
Karissa
Membre depuis le 13/04/2012
50 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 6-23, Amido Spring 2012 Membre de l'équipe Cal Poly, Team 6-23, Amido Spring 2012
CPSU-AMIDO-S12S6G23
4 membres
10 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 1,201
