Aller au contenu principal
Panasonic Lumix DMC-FX37 Lens Casing Replacement
Ce dont vous avez besoin
  1. Panasonic Lumix DMC-FX37 Lens Casing Replacement, Panasonic Lumix DMC-FX37 Disassembly: étape 1, image 1 de 2 Panasonic Lumix DMC-FX37 Lens Casing Replacement, Panasonic Lumix DMC-FX37 Disassembly: étape 1, image 2 de 2
    • Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
  2. Panasonic Lumix DMC-FX37 Lens Casing Replacement: étape 2, image 1 de 2 Panasonic Lumix DMC-FX37 Lens Casing Replacement: étape 2, image 2 de 2
    • Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely.
  3. Panasonic Lumix DMC-FX37 Lens Casing Replacement: étape 3, image 1 de 2 Panasonic Lumix DMC-FX37 Lens Casing Replacement: étape 3, image 2 de 2
    • On the opposite side of the camera, remove the two 3 mm screws.
    • Remove the bottom side panel and place it with its respective 3 mm screw.
  4. Panasonic Lumix DMC-FX37 Lens Casing Replacement: étape 4, image 1 de 3 Panasonic Lumix DMC-FX37 Lens Casing Replacement: étape 4, image 2 de 3 Panasonic Lumix DMC-FX37 Lens Casing Replacement: étape 4, image 3 de 3
    • Remove the front panel (the panel around the lens casing) from the camera.
    • Remove the two ribbon cables connected to the back panel (the panel this the LCD screen) by lifting up on their respective tabs and gently pulling out the cord.
    • Caution: When removing the back panel, the two ribbon cables are relatively delicate and must both be disconnected before the panel can be entirely removed.
    • Remove the back panel from the camera.
  5. Panasonic Lumix DMC-FX37 Lens Casing Replacement: étape 5, image 1 de 1
    • Remove the top control panel (connected to the flash battery) from the camera.
    • The top control panel is connected to the rest of the camera by a delicate multi-pin plug. Be careful as to not bend the pins!
  6. Panasonic Lumix DMC-FX37 Lens Casing Replacement, Lens Casing: étape 6, image 1 de 2 Panasonic Lumix DMC-FX37 Lens Casing Replacement, Lens Casing: étape 6, image 2 de 2
    • Unscrew the silver 2mm screw from the protection panel.
    • Unscrew the three black 8mm screws from the protection panel.
    • Be sure to remember where these screws go, inserting a longer screw in a short slot can damage your device!
    • Remove the protection panel entirely.
  7. Panasonic Lumix DMC-FX37 Lens Casing Replacement: étape 7, image 1 de 1
    • Insert the flat end of a spudger underneath the motherboard and twist. This will disconnect it from the rest of the device.
  8. Panasonic Lumix DMC-FX37 Lens Casing Replacement: étape 8, image 1 de 2 Panasonic Lumix DMC-FX37 Lens Casing Replacement: étape 8, image 2 de 2
    • Using the pointed end of a spudger, flip up the two black tabs holding the ribbon cables in place.
  9. Panasonic Lumix DMC-FX37 Lens Casing Replacement: étape 9, image 1 de 2 Panasonic Lumix DMC-FX37 Lens Casing Replacement: étape 9, image 2 de 2
    • Unscrew the three 3mm screws holding the photoreceptor in place.
    • Lift the photoreceptor and gently pull it to release the now disconnected ribbon cable.
  10. Panasonic Lumix DMC-FX37 Lens Casing Replacement: étape 10, image 1 de 1
    • Gently lift and remove the lens casing, pulling it free from the now disconnected ribbon cable.
Ben DuBose
Membre depuis le 01/30/18
327 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team S2-G3, Johnson Spring 2018 Membre de l'équipe Baylor, Team S2-G3, Johnson Spring 2018
BU-JOHNSON-S18S2G3
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 429
