Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
  1. Make sure the power is off by making sure the switch is to the right. The power switch can be found on the top side of the camera.
    • Make sure the power is off by making sure the switch is to the right. The power switch can be found on the top side of the camera.
  2. Use the Philips #00 Screwdriver on the screw on the left side of the camera. There is another screw on the underside of the camera that is part of the left cover.
    • Use the Philips #00 Screwdriver on the screw on the left side of the camera.
    • There is another screw on the underside of the camera that is part of the left cover.
  3. Use the Philips #00 Screwdriver to remove the two screws on the right cover of the camera.
    • Use the Philips #00 Screwdriver to remove the two screws on the right cover of the camera.
  4. Use the Philips #00 Screwdriver to remove the screws on the bottom side of the camera. Make sure to grasp the camera because these are the last two screws that hold the camera in place. Carefully place the opening tool between the two covers and gently apply force upward to separate the covers.
    • Use the Philips #00 Screwdriver to remove the screws on the bottom side of the camera.
    • Make sure to grasp the camera because these are the last two screws that hold the camera in place.
    • Carefully place the opening tool between the two covers and gently apply force upward to separate the covers.
  5. There are two digitizer cables that connect the LCD Screen to the camera motherboard. The digitizer cables are held down by retaining flats. Carefully use the opening tool to push the retaining flats upward to allow the digitizer cables to disconnect.
    • There are two digitizer cables that connect the LCD Screen to the camera motherboard.
    • The digitizer cables are held down by retaining flats.
    • Carefully use the opening tool to push the retaining flats upward to allow the digitizer cables to disconnect.
  6. Carefully use the opening tool to remove the LCD Screen from the glass frame. Carefully use the opening tool to remove the LCD Screen from the glass frame.
    • Carefully use the opening tool to remove the LCD Screen from the glass frame.
  7. Carefully use the opening tool to seperate the screen from the frame. Carefully use the opening tool to seperate the screen from the frame.
    • Carefully use the opening tool to seperate the screen from the frame.
Ever Escobar
Membre depuis le 08/02/2018
145 Réputation
1 tutoriel rédigé
Équipe
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 349
