Aller au contenu principal
Panasonic Lumix DMC-FZ35 LCD Replacement
Ce dont vous avez besoin
  1. Panasonic Lumix DMC-FZ35 LCD Replacement, Clear compartment: étape 1, image 1 de 1
    • Remove the battery and memory card from the unit.
  2. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove side screws: étape 2, image 1 de 2 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove side screws: étape 2, image 2 de 2
    • Remove 1 screw (0.4mm) from left side of unit
    • Remove 1 screw (0.4mm) from right side of unit near Strap bar.
    • Remove 1 screw (0.6mm) from right side of unit next to usb door
  3. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove Screws from Bottom: étape 3, image 1 de 1
    • Remove 3 Screws from bottom of unit
    • Remove 2 (0.6mm) screws next to door
    • Remove 1 (0.4mm) screw opposite of door
  4. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove top screw: étape 4, image 1 de 1
    • Raise the Pop-Up flash by pushing the flash button.
    • Remove the screw (0.6mm) from underneath the flash assembly.
  5. Panasonic Lumix DMC-FZ35 LCD Replacement, Accessing the flex cables: étape 5, image 1 de 2 Panasonic Lumix DMC-FZ35 LCD Replacement, Accessing the flex cables: étape 5, image 2 de 2
    • Please be careful. Do not lift the cover fully because it is still attached to the Main Board via flex cables.
    • Lift the cover slightly as shown in picture # 1
    • Tilt the back cover as shown in picture #2. Be careful because the flex cables are still attached.
  6. Panasonic Lumix DMC-FZ35 LCD Replacement, Release the Flex cables: étape 6, image 1 de 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Release the Flex cables: étape 6, image 2 de 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Release the Flex cables: étape 6, image 3 de 3
    • Flip up LCD cable clamp with a spudger or other tool.
    • Flip up backlite cable clamp with a spudger or other tool
    • Removal of the mic wire is optional. My suggestion is to leave it attached. The mic can get damaged if you pull on the wire.
  7. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the mic: étape 7, image 1 de 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the mic: étape 7, image 2 de 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the mic: étape 7, image 3 de 3
    • Remove the 2 screws (0.4mm) that are holding the mic assembly
    • Next step (shown in picture #2) remove the metal mic hold part.
    • Next step (shown in picture #3) use a spudger to pry off the mic. Careful not to damage the wiring.
  8. Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the LCD: étape 8, image 1 de 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the LCD: étape 8, image 2 de 3 Panasonic Lumix DMC-FZ35 LCD Replacement, Remove the LCD: étape 8, image 3 de 3
    • Release the hold clips that hold the LCD retainer in place.
    • Remove the LCD metal retainer plate as shown in picture #2
    • Remove the LCD as shown in picture # 3
  9. Panasonic Lumix DMC-FZ35 LCD Replacement, Swap out Old LCD: étape 9, image 1 de 1
    • Swap out your old LCD with the new one.
    • If your backlite is ok you can buy only the LCD Display. But it is easier to purchase the LCD with the backlite attached. Replacement LCD Display VYQ5034
Sales Cameraparts4you
Membre depuis le 07/01/16
3 150 Réputation
20 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 1,446
