Aller au contenu principal
Panasonic Lumix DMC-G5 LCD Replacement
Ce dont vous avez besoin
  1. Panasonic Lumix DMC-G5 LCD Replacement, LCD: étape 1, image 1 de 2 Panasonic Lumix DMC-G5 LCD Replacement, LCD: étape 1, image 2 de 2
    • Use J0 screwdriver to remove the two 3.2 mm screws from the outside of the assembly.
    • Use the J0 screwsdriver to remove the two 5.6 mm screws from the inside of the face near the swivel.
    • Rotate the face to more easily gain access to the screws.
  2. Panasonic Lumix DMC-G5 LCD Replacement: étape 2, image 1 de 2 Panasonic Lumix DMC-G5 LCD Replacement: étape 2, image 2 de 2
    • Slide the wide plastic opening tool underneath the crack of the side of the face and separate the components.
  3. Panasonic Lumix DMC-G5 LCD Replacement: étape 3, image 1 de 1
    • Carefully remove the filament connections from the LCD backing by lifting the black lever up first on the connector, then pulling gently outward from the LCD backing with your fingers.
    • Replace the filament connections into the backing of the new LCD face to complete replacement..
Gabriel Gonzalez Jr
Membre depuis le 02/14/17
325 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-3, Kass Spring 2017 Membre de l'équipe USF Tampa, Team 1-3, Kass Spring 2017
USFT-KASS-S17S1G3
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 14
Total : 2,109
