Aller au contenu principal
Panasonic Lumix DMC-ZS25 Power Button Replacement
Ce dont vous avez besoin
  1. Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: étape 1, image 1 de 3 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: étape 1, image 2 de 3 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: étape 1, image 3 de 3
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 2, image 1 de 1
    • Use the plastic opening tool to open the outer cover of your device.
    • The easiest place to open your device is from the HDMI port.
    • Open it gently to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 3, image 1 de 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 3, image 2 de 2
    • Use a spudger to detach the ribbon cable.
    • Be careful when you use the spudger because you do not want to break the the ribbon.
  4. Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 4, image 1 de 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 4, image 2 de 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 4, image 3 de 3
    • Remove the button board using the plastic opening tool.
    • Remove the screen. Lift the screen from the right hand side.
    • After your hear a "click" sound, you have successfully opened the screen.
  5. Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 5, image 1 de 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 5, image 2 de 2
    • Remove the two black screws that are located beneath the screen.
    • Lift the metal cover using the plastic opening tool.
  6. Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 6, image 1 de 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 6, image 2 de 2
    • Use the plastic opener to remove the side covers.
  7. Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 7, image 1 de 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 7, image 2 de 2
    • After removing the side covers, you will be able to take away the front cover with your hands.
    • Do not apply too much pressure on the outer cover of your device to avoid damage.
  8. Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 8, image 1 de 1
    • To release the top cover of the camera, you need to open the 3.70 mm screw shown in the picture.
  9. Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 9, image 1 de 1
    • Remove the top cover using the plastic opening tool.
  10. Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 10, image 1 de 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 10, image 2 de 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: étape 10, image 3 de 3
    • After removing the top cover of the camera, you will be able to easily remove the power button with your hand.
Abbas Khan
Membre depuis le 01/21/15
482 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 9-5, Brown Winter 2015 Membre de l'équipe USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
3 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 550
