Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Use this guide to replace the camera's battery.
Pièces
Aucune pièce spécifiée.
  1. Locate the small, hinged door on the bottom of the camera.
    • Locate the small, hinged door on the bottom of the camera.
  2. Using your fingernail or a spudger, push the small, grey switch on the hinged door from the left (locked) to the right (unlocked).
    • Using your fingernail or a spudger, push the small, grey switch on the hinged door from the left (locked) to the right (unlocked).
    • The hinged door should swing open after unlocking.
  3. Using your fingernail or a spudger, push down on the small, grey tab holding the battery in place.
    • Using your fingernail or a spudger, push down on the small, grey tab holding the battery in place.
    • This should release the battery.
  4. Pull the battery out of the camera. The battery should slide out easily.
    • Pull the battery out of the camera.
    • The battery should slide out easily.
Équipe
Cal Poly, Team 13-60, Johann Spring 2013 Membre de l'équipe Cal Poly, Team 13-60, Johann Spring 2013
CPSU-JOHANN-S13S13G60
3 membres
10 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 937
