Introduction
When the Fan gets dusty and the air louvers pollute with grease and dust from the kitchen, a lower airflow occurs and the refrigerator needs more electric-power, makes more noise and cools bad. So you have to clean it.
WARNING: REFRIGERATOR CONTAINS FLAMMABLE GAS. IF THE GAS-PIPE LEAKS, AN EXPLOSIVE AIR MIXTURE ACCRUES. IT IS VERY DANGEROUS IF YOU DONT WORK PROPER AND CLEAN. DONT DO THIS AT HOME IF YOU ARE NOT SURE IF YOU CAN DO THIS.
Outils
Pièces
Aucune pièce spécifiée.
First you have to empty the fridge, because when you move it the things inside could fall over. Move it away from the wall. Take care of the waterhose.
On the picture yoou see the bad clogged air louvers on the backside of my fridge. This is the filth from only THREE YEARS ! The air cant flow unhindered, thats very bad for the fridge.
When you open it, Be VERY careful, in the pipes is a flammable gas.
There are PH2 screws on the backplate. One is hidden behind the waterhose.
All screws have the same length
In the green circle, there is the water outlet from the reservoir of the defrosting automatic. there is water in it ! So open the plate slowly.
I had to cut the waterhose, when you do this too dont forget to close the faucet. I put some aluminiumfoil on the hose, so there cant get any dust in the hose, because there is lots of dust and its not good when dust gets into the waterhose of the fridge. You must have a 1/4" coupler to reassmble the waterhose when you are done !!!
4 autre(s) ont terminé cette réparation.
