Introduction
A guide to get to and replace the camcorder's micophone.
Outils
Pièces
Aucune pièce spécifiée.
Using a plastic opening tool, remove the record/playback and record/power control knobs from the camcorder.
Rotate the camcorder so that the tape compartment is facing you.
Remove the single 4.5mm black screw above the hook for the hand strap.
Undoing the strap on one end may help.
Rotate the camcorder so that the lens is facing you.
Remove the single 4.5mm black screw from the front panel.
Using a #00 phillips screwdriver, remove the four 4mm screws holding the circuit board in place.
