Aller au contenu principal
Panasonic PV-GS9 Motherboard Replacement
Ce dont vous avez besoin
  1. Panasonic PV-GS9 Motherboard Replacement, Microphone Replacement: étape 1, image 1 de 3 Panasonic PV-GS9 Motherboard Replacement, Microphone Replacement: étape 1, image 2 de 3 Panasonic PV-GS9 Motherboard Replacement, Microphone Replacement: étape 1, image 3 de 3
    • Locate the blue plastic tool opener, then remove both the round record/playback and record/power control knobs by prying it open from the camcorder.
  2. Panasonic PV-GS9 Motherboard Replacement: étape 2, image 1 de 2 Panasonic PV-GS9 Motherboard Replacement: étape 2, image 2 de 2
    • Open the tape compartment.
    • Flip over the camcorder and find the two 4.5mm screws, which are approximately 2 inches apart.
    • Using a #00 Phillips screwdriver, remove the screws
  3. Panasonic PV-GS9 Motherboard Replacement: étape 3, image 1 de 3 Panasonic PV-GS9 Motherboard Replacement: étape 3, image 2 de 3 Panasonic PV-GS9 Motherboard Replacement: étape 3, image 3 de 3
    • Use a plastic prying tool, remove the gray trim piece by opening and gently prying it off from top of the camcorder.
    • Be gentle when removing the trim piece. The plastic parts are fragile and can break easily.
  4. Panasonic PV-GS9 Motherboard Replacement: étape 4, image 1 de 1
    • Rotate the camcorder so that the camera lens is facing you.
    • Remove the four black 4.5mm screws, sitting behind the battery.
    • Remove the 5th screw to the right of the battery dock.
    • Remove the battery by gently pulling away from the camcorder.
    • Organize the screws in a sorting compartment to avoid losing them.
  5. Panasonic PV-GS9 Motherboard Replacement: étape 5, image 1 de 2 Panasonic PV-GS9 Motherboard Replacement: étape 5, image 2 de 2
    • Rotate the camcorder so that the tape compartment is facing you.
    • Remove the single 4.5mm black screw above the hook for the hand strap.
    • Undoing the strap on one end may help.
    • Rotate the camcorder so that the lens is facing you.
    • Remove the single 4.5mm black screw from the front panel.
  6. Panasonic PV-GS9 Motherboard Replacement: étape 6, image 1 de 2 Panasonic PV-GS9 Motherboard Replacement: étape 6, image 2 de 2
    • Rotate the camcorder so that the bottom is facing towards you.
    • Remove the single remaining 4.5mm black screw from the bottom.
    • Remove the four silver 4.5mm screws from the body.
  7. Panasonic PV-GS9 Motherboard Replacement: étape 7, image 1 de 1
    • Open the LCD screen on the side of the camcorder.
    • Using a #00 screwdriver, remove the two 4.5mm silver screws located on either side of the hinge of the LCD screen.
  8. Panasonic PV-GS9 Motherboard Replacement: étape 8, image 1 de 2 Panasonic PV-GS9 Motherboard Replacement: étape 8, image 2 de 2
    • Carefully detatch the front cover from the body of the camcorder.
    • This should come apart with relative ease; however, a plastic pryer tool may help remove the panel if it is struggling to come apart.
    • Be careful as there is a ribbon cable attached to the front panel and the camcorder body, DO NOT tug at it when you remove this panel.
  9. Panasonic PV-GS9 Motherboard Replacement: étape 9, image 1 de 2 Panasonic PV-GS9 Motherboard Replacement: étape 9, image 2 de 2
    • Using your fingers, carefully pull the ribbon cable away from the logic board to disconnect it.
  10. Panasonic PV-GS9 Motherboard Replacement, LCD Panel Removal: étape 10, image 1 de 2 Panasonic PV-GS9 Motherboard Replacement, LCD Panel Removal: étape 10, image 2 de 2
    • Remove the indicated 4.5mm screws from the LCD side of the camera.
  11. Panasonic PV-GS9 Motherboard Replacement: étape 11, image 1 de 3 Panasonic PV-GS9 Motherboard Replacement: étape 11, image 2 de 3 Panasonic PV-GS9 Motherboard Replacement: étape 11, image 3 de 3
    • Place a plastic opening tool under the bottom of the blue panel beneath the camcorder.
    • Move the plastic opening tool up the side of the camcorder as shown. Carefully separate the LCD panel from the rest of the camcorder.
    • Remove the panel from the camcorder.
    • Using two tools can help for stability.
  12. Panasonic PV-GS9 Motherboard Replacement: étape 12, image 1 de 3 Panasonic PV-GS9 Motherboard Replacement: étape 12, image 2 de 3 Panasonic PV-GS9 Motherboard Replacement: étape 12, image 3 de 3
    • Before removing the LCD panel from the camcorder, disconnect all the ribbon cables joining the LCD panel to the logic board.
    • There may be multiple ribbon cables attached to the same point on the logic board.
  13. Panasonic PV-GS9 Motherboard Replacement, Motherboard: étape 13, image 1 de 3 Panasonic PV-GS9 Motherboard Replacement, Motherboard: étape 13, image 2 de 3 Panasonic PV-GS9 Motherboard Replacement, Motherboard: étape 13, image 3 de 3
    • Using the spudger, remove the few remaining ribbon cables from the logic board.
  14. Panasonic PV-GS9 Motherboard Replacement: étape 14, image 1 de 3 Panasonic PV-GS9 Motherboard Replacement: étape 14, image 2 de 3 Panasonic PV-GS9 Motherboard Replacement: étape 14, image 3 de 3
    • To remove the logic board from the body, use the #00 phillips head screwdriver and remove the 4mm silver screw from right side of the board.
    • Next, rotate the camcorder so the front is facing you and remove the 4mm silver screw from the front panel.
    • Carefully lift the logic board away from the camcorder.
2 autres ont terminé cette réparation.
Tommy
Membre depuis le 04/18/10
133 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 7-9, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 7-9, Maness Spring 2010
CPSU-MANESS-S10S7G9
4 membres
15 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 13
Total : 3,052
