Aller au contenu principal
Panasonic RQ-2102 Cassette Holder Spring Replacement
Ce dont vous avez besoin
  1. Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: étape 1, image 1 de 3 Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: étape 1, image 2 de 3 Panasonic RQ-2102 Cassette Holder Spring Replacement, Cassette Holder Spring: étape 1, image 3 de 3
    • Remove the three screws from the back of the device body.
    • Remove both screws from the battery compartment.
    • Remove the back of the device.
    • All screws in the body of this device are the same size.
    • When pulling apart the device, both sides are connected by a cord that could be damaged if care is not taken.
  2. Panasonic RQ-2102 Cassette Holder Spring Replacement: étape 2, image 1 de 3 Panasonic RQ-2102 Cassette Holder Spring Replacement: étape 2, image 2 de 3 Panasonic RQ-2102 Cassette Holder Spring Replacement: étape 2, image 3 de 3
    • Make sure the brass colored spring by the cassette door is in the correct position.
    • Remove the screw that holds the spring if broken.
    • Remove the spring from the device.
  3. Panasonic RQ-2102 Cassette Holder Spring Replacement: étape 3, image 1 de 2 Panasonic RQ-2102 Cassette Holder Spring Replacement: étape 3, image 2 de 2
    • Replace the old spring with the new spring, making sure that it is installed in the correct position.
    • Insert the screw back into position, ensuring that it holds the spring.
    • If the spring is loose, tighten the screw.
2 autres ont terminé cette réparation.
Andrew Campbell
Membre depuis le 04/07/15
276 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 17
Total : 1,218
