Aller au contenu principal
Panasonic Toughbook CF-29 Heat Sink Replacement
Ce dont vous avez besoin
  1. Panasonic Toughbook CF-29 Heat Sink Replacement, Battery: étape 1, image 1 de 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Heat Sink Replacement: étape 2, image 1 de 2 Panasonic Toughbook CF-29 Heat Sink Replacement: étape 2, image 2 de 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Heat Sink Replacement, Back Cover: étape 3, image 1 de 1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Panasonic Toughbook CF-29 Heat Sink Replacement: étape 4, image 1 de 1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  5. Panasonic Toughbook CF-29 Heat Sink Replacement: étape 5, image 1 de 1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  6. Panasonic Toughbook CF-29 Heat Sink Replacement: étape 6, image 1 de 2 Panasonic Toughbook CF-29 Heat Sink Replacement: étape 6, image 2 de 2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  7. Panasonic Toughbook CF-29 Heat Sink Replacement: étape 7, image 1 de 1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  8. Panasonic Toughbook CF-29 Heat Sink Replacement: étape 8, image 1 de 1
    • Now the back cover should be off and you can access the inside of the casing.
  9. Panasonic Toughbook CF-29 Heat Sink Replacement, Heat Sink: étape 9, image 1 de 1
    • Locate the heat sink on the underside of the back cover.
    • It is the U shaped metallic piece.
  10. Panasonic Toughbook CF-29 Heat Sink Replacement: étape 10, image 1 de 1
    • Remove the four screws with a Phillips size 1 screwdriver.
    • One on each of the ends
    • Two on the base of the U shape
  11. Panasonic Toughbook CF-29 Heat Sink Replacement: étape 11, image 1 de 1
    • Being careful not to lose the brackets at the ends of the heat sink, lift it up and out.
Clint Kirsop
Membre depuis le 04/13/10
109 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 27-93, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 membres
26 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 5,795
