Introduction
This guide will provide you with step by step instructions to replace your Toughbook CF-29's speaker.
  1. Locate the bay door for the battery on the left side of the laptop.
    • Locate the bay door for the battery on the left side of the laptop.
  2. Slide the latch to the right and then down to unlock it.
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
    • Now the back cover should be off and you can access the inside of the casing.
    • Place the back cover infront of you so you can access the inside of it.
    • Remove the 3 screws holding in the speaker.
    • Pry out the speaker using a flat screw driver or a blue pry tool. It is held in with an adhesive.
    • Your speaker is now removed
    • Put in your replacement by following the reverse steps.
Rohun Heesen
Membre depuis le 13/04/2010
330 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 27-93, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 membres
12 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 2
Total : 5,014
