Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide will provide you with step by step instructions to replace your Toughbook CF-29's speaker.
  1. Locate the bay door for the battery on the left side of the laptop.
    • Locate the bay door for the battery on the left side of the laptop.
  2. Slide the latch to the right and then down to unlock it. Pull out the battery.
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Begin by turning the laptop upside down with the handle towards you.
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  4. Remove the panel and set it aside.
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  5. Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  6. Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive. Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  7. Be careful when lifting the cover as you may damage some connections.
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  8. Now the back cover should be off and you can access the inside of the casing.
    • Now the back cover should be off and you can access the inside of the casing.
  9. Place the back cover infront of you so you can access the inside of it.
    • Place the back cover infront of you so you can access the inside of it.
    • Remove the 3 screws holding in the speaker.
  10. Pry out the speaker using a flat screw driver or a blue pry tool.  It is held in with an adhesive.
    • Pry out the speaker using a flat screw driver or a blue pry tool. It is held in with an adhesive.
  11. Your speaker is now removed
    • Your speaker is now removed
    • Put in your replacement by following the reverse steps.
Rohun Heesen
Membre depuis le 13/04/2010
330 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 27-93, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 membres
24 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 5,094
