Aller au contenu principal
Pantech CDM8975 Keyboard Replacement
Ce dont vous avez besoin
  1. Pantech CDM8975 Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Remove the battery.
    • Remove four Phillips screws.
  2. Pantech CDM8975 Keyboard Replacement: étape 2, image 1 de 1
    • Pry up the plastic layer with a plastic opening tool.
    • NOTE: Be careful that you do not separate the two plastic parts completely they are fragile and may break if pulled too hard.
  3. Pantech CDM8975 Keyboard Replacement, Remove Keyboard: étape 3, image 1 de 1
    • Slide out the keyboard carefully in between the two layers.
  4. Pantech CDM8975 Keyboard Replacement: étape 4, image 1 de 1
    • Insert the new keyboard in between the two layers carefully.
  5. Pantech CDM8975 Keyboard Replacement: étape 5, image 1 de 1
    • Check if the edges are perfectly aligned between the two plastic layers after you insert the keyboard.
  6. Pantech CDM8975 Keyboard Replacement: étape 6, image 1 de 1
    • Press the two plastic layers back together.
    • Reinsert the four screws and place the battery and cover back.
You now have a new keyboard.
2 autres ont terminé cette réparation.
Richard
Membre depuis le 02/13/14
116 Réputation
1 tutoriel rédigé
Équipe
Ohio State, Team 1-4, Meza Spring 2014 Membre de l'équipe Ohio State, Team 1-4, Meza Spring 2014
OSU-MEZA-S14S1G4
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 245
