Introduction
Use this guide to replace, propellers, shafts, and gears on a Parrot AR.Drone 2.0.
AR.Drone 2.0 spare parts and mounting tools are available from several Parrot retailers.
Ce dont vous avez besoin
Vidéo d'introduction
Disconnect the battery by pulling the two red wires apart.
Remove the battery by releasing the battery retaining straps.
Are you referring to the clips in step three? If so, i highly recommend a hard, flat edged tool like a plastic spudger or flat head screw driver. Push is against the opposite side of the C clip that is opened with roughly the same force you applied to get it off. You have to be really careful that you push it directly horizontal or else you might damage the shaft or risk loosing the clip if it pops off.
4 autres ont terminé cette réparation.
