Aller au contenu principal
Parrot Bebop Drone GPS Board Replacement
Ce dont vous avez besoin
  1. Parrot Bebop Drone GPS Board Replacement, Battery: étape 1, image 1 de 2 Parrot Bebop Drone GPS Board Replacement, Battery: étape 1, image 2 de 2
    • Begin by removing the velcro strap around the battery.
  2. Parrot Bebop Drone GPS Board Replacement: étape 2, image 1 de 2 Parrot Bebop Drone GPS Board Replacement: étape 2, image 2 de 2
    • While holding onto the nose, gently pull the battery away from the nose.
  3. Parrot Bebop Drone GPS Board Replacement: étape 3, image 1 de 3 Parrot Bebop Drone GPS Board Replacement: étape 3, image 2 de 3 Parrot Bebop Drone GPS Board Replacement: étape 3, image 3 de 3
    • Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
  4. Parrot Bebop Drone GPS Board Replacement, Styrofoam Nose: étape 4, image 1 de 2 Parrot Bebop Drone GPS Board Replacement, Styrofoam Nose: étape 4, image 2 de 2
    • Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
  5. Parrot Bebop Drone GPS Board Replacement: étape 5, image 1 de 1
    • Take the metal spudger, to remove the double stick tape from the foam.
  6. Parrot Bebop Drone GPS Board Replacement: étape 6, image 1 de 1
    • Remove the styrofoam nose from over the drone's camera by sliding it towards the front of the drone at an angle.
  7. Parrot Bebop Drone GPS Board Replacement, GPS Board: étape 7, image 1 de 1
    • Remove the cable from the top of the GPS module.
  8. Parrot Bebop Drone GPS Board Replacement: étape 8, image 1 de 2 Parrot Bebop Drone GPS Board Replacement: étape 8, image 2 de 2
    • Remove the two 6mm T5 torx screws holding the GPS module. There is one screw on each side.
    • Remove the 4mm T5 Screw holding the GPS Module.
  9. Parrot Bebop Drone GPS Board Replacement: étape 9, image 1 de 1
    • Remove the GPS board by lifting it off of the metal frame.
4 autres ont terminé cette réparation.
Austin
Membre depuis le 02/02/17
185 Réputation
1 tutoriel rédigé
Équipe
UW Tacoma, Team 1-3, Rose Winter 2017 Membre de l'équipe UW Tacoma, Team 1-3, Rose Winter 2017
UWT-ROSE-W17S1G3
4 membres
5 tutoriels rédigés
Un commentaire
With voice driving directions maps <a href="https://play.google.com/store/apps/detai...
">GPS Voice Nevigation with speed</a> limits with speaking ,user can get accurate gps coordinates for car GPS navigation.In gps driving guide 2019 users can listen to voice input for voice navigation which gives out all of the audio instructions for direction gps towards destination point on the maps
Albert - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 13
Total : 2,667
