Aller au contenu principal
Parrot Hydrofoil Orak Propellers Replacement
  1. Parrot Hydrofoil Orak Propellers Replacement, Propellers: étape 1, image 1 de 3 Parrot Hydrofoil Orak Propellers Replacement, Propellers: étape 1, image 2 de 3 Parrot Hydrofoil Orak Propellers Replacement, Propellers: étape 1, image 3 de 3
    • Locate the propellers of the same angle, each diagonally across from each other.
    • Locate the propellers of the opposite angle, located diagonally across from each other.
    • Grip each white propeller firmly and pull up to remove.
    • Removing the propellers may require a decent use of force.
    • When replacing the propellers make sure to place the corresponding set in the right position, diagonally across from each other to ensure proper liftoff.
Jacob Munson
Membre depuis le 10/06/16
200 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 20-2, Livingston Fall 2016 Membre de l'équipe Cal Poly, Team 20-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G2
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 11
Total : 736
