Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Patching a 125 2 stroke fuel tank
Ce dont vous avez besoin
  1. Patching a 125 2 stroke fuel tank, Patching a 125 2 stroke fuel tank: étape 1, image 1 de 1
    • First, you will need to sand down the rough edges around the hole in fuel tank.
    • Make sure the hole in the fuel tank and its surrounding is as smooth as possible.
    Demander à FixBot
    Ajouter un commentaire
  2. Patching a 125 2 stroke fuel tank: étape 2, image 1 de 1
    • Once the hole is smooth. Apply fuel patch with q-tip over hole and the surrounding edges.
    Demander à FixBot
  3. Patching a 125 2 stroke fuel tank: étape 3, image 1 de 1
    • Make sure that the ointment is spread thickly over the hole.
    Demander à FixBot
  4. Patching a 125 2 stroke fuel tank: étape 4, image 1 de 1
    • Avoid having air pockets in the ointment. Air pockets may make the patch less effective or not seal at all.
    Demander à FixBot
    • Once the ointment is spread over smoothly, you will need to rub the edges out so there is no edge that can be caught on something.
    Demander à FixBot
  5. Patching a 125 2 stroke fuel tank: étape 6, image 1 de 1
    • Let the patch dry over.
    • Try not to touch patch until completely dry. This may take a couple hours.
    Demander à FixBot
  6. Patching a 125 2 stroke fuel tank: étape 7, image 1 de 1
    • Next, you will need to check the patch after completely dry. Make sure there is no bubbles or edges where there could be another potential leak.
    Demander à FixBot
    • Once patch is dry put fuel in the tank.
    Demander à FixBot
    • When tank is full check to see if there are any leaks in the patch. Leaks consist of fuel dripping or even air leak from patch.
    Demander à FixBot
    • If there are leaks scrape off patch and repeat process.
    Demander à FixBot
  7. Patching a 125 2 stroke fuel tank: étape 11, image 1 de 1
    • When there are no leaks start riding. Your tank is now patched. Check up on patch after ride to make sure it is still sealed.
    Demander à FixBot
3 autres ont terminé cette réparation.
Andrew
Membre depuis le 02/17/15
1 387 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 15
30 derniers jours : 80
Total : 2,523
