Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Patching a Bicycle Tire Inner Tube
Ce dont vous avez besoin
  1. Patching a Bicycle Tire Inner Tube, Inner Tube: étape 1, image 1 de 1
    • Press the valve core while applying pressure to the tire to deflate the tire.
    Demander à FixBot
    Ajouter un commentaire
  2. Patching a Bicycle Tire Inner Tube: étape 2, image 1 de 2 Patching a Bicycle Tire Inner Tube: étape 2, image 2 de 2
    • Insert the flat part of a tire lever under the tire coping. Apply pressure to the other end of the lever to lift the tire up and out of the wheel.
    • Slide the lever around the circumference of the wheel to completely remove the tire.
    • Alternatively, if you have multiple tire levers, see if you can clip the first lever to a spoke to keep it in place. Then insert the second lever a few inches away. Clip it to a spoke. Insert the third lever a few more inches along. Take out the second lever and insert it it a few inches past the third. Work along the rim until the tire pops off.
    Demander à FixBot
  3. Patching a Bicycle Tire Inner Tube: étape 3, image 1 de 1
    • Remove the tube by pushing the valve through the hole in the rim and pulling the tube out from under the tire.
    Demander à FixBot
  4. Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: étape 4, image 1 de 2 Patching a Bicycle Tire Inner Tube, Patching a Bicycle Tire Inner Tube: étape 4, image 2 de 2
    • Locate the leak by first over inflating the tire.
    • Place the tire under water and look for bubbles to find the leak.
    Demander à FixBot
  5. Patching a Bicycle Tire Inner Tube: étape 5, image 1 de 1
    • Mark the hole with a marker, and completely deflate the tire.
    Demander à FixBot
  6. Patching a Bicycle Tire Inner Tube: étape 6, image 1 de 1
    • Select a patch kit that you will use to patch the hole. Try to pick a patch that is appropriate for the size of the hole.
    Demander à FixBot
  7. Patching a Bicycle Tire Inner Tube: étape 7, image 1 de 1
    • Clean the area near the hole with soap and water, then dry it thoroughly.
    • Rough up the area around the hole with an abrasive surface such as sand paper until the area around the leak loses its shine.
    Demander à FixBot
  8. Patching a Bicycle Tire Inner Tube: étape 8, image 1 de 1
    • Apply rubber cement to an area around the hole that is bigger than the patch to ensure that the patch bonds completely.
    Demander à FixBot
  9. Patching a Bicycle Tire Inner Tube: étape 9, image 1 de 1
    • Apply the patch to the area.
    Demander à FixBot
  10. Patching a Bicycle Tire Inner Tube: étape 10, image 1 de 1
    • Apply pressure to the patch until the rubber cement is dry.
    Demander à FixBot
To reassemble your bike, follow these directions from step 6
2 autres ont terminé cette réparation.
Brett Hartt
Membre depuis le 04/12/10
132 251 Réputation
144 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
123 membres
31 356 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 6
30 derniers jours : 37
Total : 2,386
